52 f2 wheel cylinder? - Ford Truck Enthusiasts Forums
Old 09-22-2011, 09:29 PM
Destroyer's Avatar
Destroyer
Destroyer is offline
Destroyer is starting off with a positive reputation.
I have searched for days but can't find what I thought I read somewhere.
I got a front 52 f2 axle that I'm going to use in a model A, I thought I read at one time that there was a dual wheel cylinder that would work instead of the single piston wheel cylinder, is there one I could use or did I just dream this up?
Thanks.
Old 09-23-2011, 12:57 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is online now
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Doesn't the F2 have a 6 lug bolt pattern?
Old 09-23-2011, 03:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1D-2061 Right & 1D-2062 Left .. Front Wheel Cylinders / 1948/52 F2/F3, 1953/56 F250/350.
1948/52 F2's & 1953/56 F250's (1957/98 F250's) have 8 lug wheels on a 6.50" bolt circle.
1948/52 F3's & 1953/56 F350's (1957/66 F350's) have 6 lug wheels on a 7.25" bolt circle.
Old 09-23-2011, 08:43 AM
Destroyer's Avatar
Destroyer
So are these the part numbers for dual piston wheel cylinders?
And if so what supplier should I go through? Napa?
Thanks,
Phil
Old 09-23-2011, 08:53 AM
Destroyer's Avatar
Destroyer
I looked the numbers up online and it shows the single piston cylinder, I was hopping to fond a dual that would work,
Oh well I guess ill just stick with the stock ones.
Thanks.
Old 09-23-2011, 09:11 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
bobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant future
Ilya, '48-52 F-2s are eight lug.
I think, but I'm no expert by far, that he may be using the F-2 backing plates with Buick drums. That seems to be the hot combination on the HAMB.
I think the backing plates are the same for all of them, but again I'm not totally sure, I'd have to check the parts catalog I have. If this is correct you could use the earlier F-2, 48-50 wheel cylinders which I was able to get without a problem at NAPA. The reproduction guys like Job Lot, Mac's and Dennis Carpenter have them but cost a few bucks more plus shipping.
Old 09-23-2011, 09:32 AM
NumberDummy
Originally Posted by Destroyer View Post
I looked the numbers up online and it shows the single piston cylinder..
Thanks.
Where did you look, wiki wiki? If so, I wouldn't trust anything wiki says.
Parts catalog pic shows 2 pistons in each cylinder (double ender), only light truck I can recall with single piston cylinders (single ender) are 1962/63 F100/250's.
ID-2061 & ID-2062: Antique Auto Supply in Arlington TX has both of these cylinders, call 'em and ask: 817-275-2381.
Fit: 1948/52 F2/F3 & 1953/56 F250/350.
Old 09-23-2011, 10:05 AM
Destroyer's Avatar
Destroyer
No I looked at part stores online,
Wheel Cylinder - Front Right - 1-1/8" Bore - F2, F250, F3 & F350 - MAC's Antique Auto Parts
And Napa
https://www.napaonline.com/Catalog/C...(P_RecType%3aA)
I will give the place you recommended a try thanks.
Old 09-23-2011, 10:12 AM
Destroyer's Avatar
Destroyer
Yeah its an 8 lug and I'm going to keep it that way. Gives it more of a heavy duty look, plus its going to be holding up a 460
Old 09-23-2011, 10:14 AM
Destroyer's Avatar
Destroyer
Napa does show this one on there site but it has a bigger bore plus its a lot more then I would like to spend.
Thanks again for your help.
Old 09-23-2011, 03:54 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Hey Phil,
Good to meet you the other day! Sweet Bronco's btw.
hope you find what you need with that axle, sorry, I'm of no help with the F2 F3 Brake stuff, Are those drums any good after you got them off?
I have an almost new set of rear brake drums from an 51 F3 (yes they are 8 lugs on a 51 F3. Bill, you mentioned above that f3's were 6 lug??? are you sure?)
I am not sure if they are the same as the rear or if they would work on the front you have or not?? these guys would definitly know.
Cheers
Josh
Old 09-23-2011, 04:04 PM
NumberDummy
No, because I goofed.
You are correct, my eyes wandered to the next parts catalog listing.
1948/52 F3: 8 lug wheels on a 6.50" bolt circle, same as 1948/52 F2, 1953/56 F250.
1953/56 F350 (1957/66 F350): 6 lug wheels on a 7.25" bolt circle.
Old 09-23-2011, 04:22 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
We all make mistakes, I just never thought that it happened to you!
, I guess we will let it slide this time, but don't let it happen again. hahaha
Do you know if the rear drums from a 51 f3 (12" drums) would fit on the front axle? I can't remember visually if the front drums look different from the rears?
Thanks
Old 09-23-2011, 04:23 PM
51PanelMan's Avatar
51PanelMan
Where's "Julie" when you need him! TEE HEE
He'd have a field day with your error and will never let you forget it.
Old 09-23-2011, 04:27 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Thats Funny Right there ! I was thinking it but didn't go that far...
speaking of dual and single piston wheel cylinders, I thought the fronts had dual pistons and rears were single piston cylinders?? or the other way around? or is that what he said and I just missed it?
Quick Reply: 52 f2 wheel cylinder?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
