hello,
i just finished swaping a 94 351w into my 92 f150 replacing a 302.
parts used
92 f150 truck
94 f150 5.0 maf engine harness
94 bronco 351w
i now have enerything togeather and running great, except i dont have wipers. everything else works but wipers. even the pee.ers work. wat am i missing that is causing them not to work?
also, the 351 has a sensor on the a/c line on the back of the compressor. my previous engine did not. any hints on how to get a/c working?
the cruise control is also not connected right now do to old one being vacume controled and maf uses electrical.
any hints or tips r apreciated.
thanks ryan
It doesn't matter how either of those systems worked on the trucks your donor parts came from because neither system has anything to do with the engine control computer, so if everything is connected as it was before the systems will work... assuming they worked before the swap that is.
Wipers worked pre swap and now they dont. All fuses r good and wires connected. I saw on another post theres something different in wiring between the 2. Just need to know Wat it is.
