f-150 engine swap question
Old Dec 29, 2006 | 11:12 PM
muddbugg's Avatar
muddbugg
I have a 94 f-150 with a 302 in it will the heads from this 5.0 fit on a 351w and how much will i have to change to put the 351w in the 94. the 351w is out of an 83 f-150. can anyone help. thanks
Old Dec 30, 2006 | 07:39 AM
lostin90s's Avatar
lostin90s
Welcome .
no the heads won't work . As for swap you swap in complete engine , fly wheel, mounts everything else should work . you might have to swap for 351 ECM but some say work fine with 302 ECM . I ussually swap the other way as I like the better MPG . (But I drive 500-600 miles week.)You will get many helpfull ,answers these guy's have done it all. Good luck
________________________________________________
94 F150 XLT SC LB 4x4 Maf 302 E4OD 3.55 rears.
Old Dec 30, 2006 | 08:59 AM
EPNCSU2006's Avatar
EPNCSU2006
The heads will work if you drill the head bolt holes to 1/2" diameter.
