Glove box insert?
Old Sep 22, 2011 | 08:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Jolly Roger Joe
... I will be buying a cheap cardboard glove box...
Just to be clear, the Dennis Carpenter liners are made of cardboard, but it's a very thick stiff board, near 1/8" thick. The way they are constructed they are very stiff. You could easily put 5 lbs of junk in there and it wouldn't flex a bit. As long as you keep them from getting soaked by a bad windshield gasket they are just fine.
Old Sep 22, 2011 | 08:25 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Yeah, pretty sure the bad windshield gasket is why mine is destroyed.
Old Sep 22, 2011 | 08:43 PM
jmadsen's Avatar
jmadsen
I thought that's why they got the sag in the middle that doc mentioned, ?? I have seen that but don't have a picture, they just kinda fell apart, plus the one in my F5 parts truck had lots of mice crap etc in it. It was one of the first things in the dumpster.
Old Sep 22, 2011 | 09:11 PM
brain75's Avatar
brain75
I believe mine is original - a lot of stuff on mine was well cared for and in worn but good shape. I will double check this weekend, but mine only has a torn up and ripped front corner and no sag in the middle if I remember it correctly. And yeah, I had a mouse nest in it after 8 years (they pulled the loose cotton mattress out of the seat and took it up for a cozy little home - no damage other than the crap, I was able to pull everything out, damp sponge it a few times and get it back to "serviceable" but worn condition.
I'm only looking at replacing because with the front torn as bad as it is, I am afraid that removing it, mounting the radio, building a wire shield for the radio it won't survive being handled that much.
[Edit] Based on the idea that a little polyester resin will waterproof it and make it strong enough to hold up the radio without sagging in 5 years I am now leaning back towards the original with a fab'd radio cubby (trying to stay as original as possible).
Old Sep 22, 2011 | 09:26 PM
Doc's Avatar
Doc
I was up there sandblasting and looked at mine again. Its no doubt original but terribly sagged in the middle. Otherwise it is constructed very similarly to the DC one.
Old Sep 22, 2011 | 09:41 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
My trucks first cardboard glove-box lasted 47 years.This one's on year five with no problems.
Old Sep 22, 2011 | 09:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's real different than mine! are the bulges on the left and right intentional? Mine goes straight back top, bottom, and both sides?? Yours looks like it's meant to clear something to the left; heater?
Old Sep 22, 2011 | 09:49 PM
brain75's Avatar
brain75
I was wondering myself - I seem to remember it just being like a oval trash can... no dents on the sides like that. It's all bad recollection at the moment cause the truck is at grandad's.
Old Sep 22, 2011 | 09:57 PM
Doc's Avatar
Doc
Believe it or not, I didn't realize how terribly bad it is sagged and deformed until I pulled the crap out of it and looked at it again tonight. I can tell that it was originally shaped like you said. That should be a testimony to how durable that cardboard is after 62 years to survive the very slow water damage. By the way, as you might have guessed, my truck needed a new windshield seal probably 30 years ago. That and new glass is on my winter bucket list.
Old Sep 23, 2011 | 01:03 AM
NtShade's Avatar
NtShade
I need an a/c for mine but not sure how to find one. Can't afford one of the new ones for sure.
Old Sep 23, 2011 | 09:50 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Looking at your pictures it appears there is no floorboard on the passenger side? How is the driver's side?
Which engine do you have? I can't remember ever seeing a flat-6 with A/C, even on the flat-V8s they are not that common. It isn't easy to get a compressor mounted on the 8s because of the belt arrangement.
Old Sep 23, 2011 | 10:56 AM
NtShade's Avatar
NtShade
I have a flat 6 in my truck but it will be taken out and a 351W or Cleveland will be put in.
I was looking for a mustang under the dash a/c, but none at the junkyard.
Old Sep 23, 2011 | 10:57 AM
  #28
NtShade's Avatar
NtShade
Floorboard is shot on the front section of my truck, where the seat is is fine but I am going to replace the entire floor.
Old Sep 24, 2011 | 07:33 PM
  #29
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Those underdash ac units are out there but you better be patient. They are getting pricey as well, Keep you eye on the local pull-a-part type yards and ebay but be prepaired to spend some coin.
After you find one then you'll still have to invest plenty of fabbrication hours and dollars making hoses, mounts, wiring, etc.
I have a unit I pulled from a 63 Galaxy that might find its way into my 49.....someday......
Bobby
Old Sep 25, 2011 | 05:56 AM
  #30
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So called "Mustang" hang-on A/C will be found in the following: 1963/65 Falcon/Comet/Fairlane/Meteor, 1965/66 Mustang, 1965/67 F100/350.
The bezel is chrome steel, has four round plastic chrome registers (O). The two A/C switches (o) are mounted between the registers (O o O O o O). There is a Ford crest (or Mercury 'head') in the upper center.
The bezel used 1963/65 is painted argent within the oval depression that surrounds the registers. The 1966 bezel is painted dark charcoal in this area.
1961/64 Galaxies also have hang-on A/C. 1961/62: The outer section of the bezel has a V shape to it, uses toggle ***** to adjust the registers.
1963/64 outer bezel is flat, doesn't use toggle ***** to adjust the registers, is marked Select-Aire.
1961/64: The bezels and rectangular registers are chromed steel. The two A/C switches are mounted in the center.
