Tranny is slipping
Old Sep 22, 2011 | 12:46 PM
WIfordf150's Avatar
WIfordf150
Tranny is slipping
Got a 93 F-150 4x4 4 sp automatic, and 2nd gear just started slipping last week. It shifts hard going in from 1st and down from 3rd when it coasts. It wont go into overdrive/road gear no matter how much i hammer on it. the overdrive button on the shifter was chewed off by the previous owners dog, but shifting into road gear wasn't a problem before all of this happened. the transmission shifted just fine before problem started, and the fluid is full. Also the speedometer went out at roughly the same time, and i looked underneath by the back of the transmission but saw no broken wires or connections. Any help or incite would be great thanks
Old Sep 22, 2011 | 01:25 PM
Lazy K's Avatar
Lazy K
You need to get the speedo working as the trans needs it. The speedo gets its signal from a sensor on top of the rear differential housing. Check that the wires to it are good. You could also try pulling it and cleaning it.
top213
May 4, 2024 02:40 PM
gpacster
15
Aug 16, 2015 11:01 AM
gossett.air
Aug 15, 2010 04:48 PM
shannondieterle
Jul 31, 2008 12:08 AM
fxdwg
Aug 30, 2005 04:01 PM
