Sponsored by: Auxito
1998 Relay Problem
Old Sep 21, 2011 | 10:00 PM
n8line1978's Avatar
n8line1978
1998 Relay Problem
I have a 1998 4.6L F-150. The truck currently won't start and I have no power (lights, radio, etc).
The #4 or #5 Relay (in the fuse area) in making a "tiiiiiccccccckkkk-tiiiiiiiiiccccccccckkkk-ttiiiiccccckkk" sound every 3-5 seconds.
What gives? Just switch out the relay and be done or is there something else to be looking at? Is there a problem elsewehere that may be causing this?
P.S. The truck ran yesterday.
Old Sep 22, 2011 | 03:43 PM
Bluegrass 7's Avatar
Bluegrass 7
Start at the battery cable ends and terminal. Clean them and make sure they are tight.
If the interior lights go out when trying the crank, there is a high resistance at some point.
The relays are just respondng to low voltage.
Good luck.
Old Sep 22, 2011 | 10:52 PM
n8line1978's Avatar
n8line1978
What should I be looking for in "high resistance"?
Old Sep 23, 2011 | 12:58 PM
Bluegrass 7
Do the mechanical cleaning and tightening along the main power route as suggested.
If you get lucky and clear the issue, then you can conclude it was a high resistance connection.
Once there is an issue from age and use, it's almost a must to go over the whole system to clear other possible issues even if you don't actually see them.
The truck is 12 years old so you need to look at it from that point.
Good luck.
fordf150farmer
1997 - 2003 F150
13
Feb 27, 2011 07:36 PM
RFD_Truckie
Electrical Systems/Wiring
Jul 10, 2009 06:00 PM
Hiflyer746
Mar 8, 2009 05:46 PM
kev03
Sep 22, 2008 02:11 PM
Karma
Mar 4, 2007 10:54 AM
