Rain guard/wind deflection help
Old Sep 26, 2011 | 07:33 PM
Fontana's Avatar
Fontana
Originally Posted by Gunny77
I just added the Weather Tech in channel vents. I like them, very easy to install, 5 mins for all 4. They were a little tight initially but once they sit in the sun with the windows up they settle in and conform nicely.
2011 F250 Lariat 4x4 CC/SB Sterling Grey w/ Limited Edition Seats<o></o>
2007 F150 King Ranch - Hers<o></o>
Did you or do you hear any wind noise as a result of the installation? I ask because I just bought Weather Tech. They look great but I do hear some wind. I thought that if I hear it tomorrow I would have it corrected.
Old Sep 27, 2011 | 10:59 AM
Big-Sarge's Avatar
Big-Sarge
Originally Posted by _red rocket_
Yes, there are two bolts behind the tweeter, for the mirror, that you need to loosen on each side to fit the AVS product in there and have it fit correctly.
Thank you Sir!
Old Sep 28, 2011 | 05:56 PM
Fontana's Avatar
Fontana
Update:
weather tech is not working. My drivers side window has wind noise. Went through two visors and still noise. Going to try URS tomorrow as they are the only other brand that reaches all the way down the window channel. If they don't work I know that my window is just offset from the factory. I hope it's the truck because those weathertech look spectacular.
Old Sep 29, 2011 | 08:02 PM
Gunny77's Avatar
Gunny77
I noticed some slight wind noise but not enough to bother me.
Old Oct 2, 2011 | 11:20 AM
Fontana's Avatar
Fontana
The wind noise has become so pronounced that I now have to do something. I think my window is off track. It's not sealing properly. I think what happened was when the installer pushed my endow up to get a proper initial seal the window became unbalanced and loose. I suppose I'll need to use warranty support.
Old Oct 12, 2011 | 08:25 AM
Fontana's Avatar
Fontana
Weather Tech Update
So I took my truck to my dealership to find out if there was anything wrong with my driver's side door. Yes, my window was a little loose but it didn't cure the wind noise. The passenger side is a perfect fit but for some odd reason the driver side still has some noise. As soon as I take the guard out the wind noise stops.
I really like the Weather Tech rain guards so I am going to just deal with some wind noise. The dealerdip was very helpful and did not charge me anything after two days of trial and error.
Old Oct 12, 2011 | 08:27 AM
Fontana's Avatar
Fontana
Gunny77<
May I assume that you are an out of uniform Marine? If so do you know of any web sites that I can get some USMC window decals?
Stephen67
Jun 10, 2012 11:24 PM
ReBilld
24
Jun 6, 2012 05:53 AM
hick67
Sep 25, 2010 03:55 AM
scottzj
Jul 23, 2010 09:44 PM
