EBP Sensor
Old Sep 21, 2011 | 04:58 AM
big dirty's Avatar
big dirty
EBP Sensor
EGR Pressure Feedback Sensor ............. is this the same as what is called the EBP Sensor?
Old Sep 21, 2011 | 05:50 AM
npccpartsman's Avatar
npccpartsman
EBP = exhaust back pressure sensor. It's mounted on the driverside exhaust manifold and is connected to the manifold by a short steel tube. I've never heard it refered to as EGR Pressure feedback sensor.
After a little more research that's more of a gas burner thing. What's up?
Old Sep 21, 2011 | 06:50 AM
big dirty's Avatar
big dirty
Nothing...... was trying to find one over on (Rock-Auto) and it was showing it under:
2006 Ford F-250 6.0 Diesel (Emissions)
Looks like the EBP sensor in the pic and I thought I would ask the professionals.
Old Sep 22, 2011 | 05:36 AM
matty169's Avatar
matty169
ebp and a injector?
If someone told you that you need both, odds are you don't. If the Ebp is bad or plugged the injector test can look bad and cause a miss or stumble.
Old Sep 22, 2011 | 07:21 AM
big dirty's Avatar
big dirty
Yeah ..... The EBP and MAP sensors are the only sensors that I haven't replaced duing my stumble ordeal. I did clean the tube and also cleaned the EBP sensor.
I have read that if the EBP sensor has failed that it will cause the EGR valve to not function properly and throw the common EGR code ( I can't remember which code).
My quetion though:
I was looking for the EBP sensor on Rock-Auto and seen a listing under (Emissions) for a 2006 6.0 Diesel.
and was wondering if ........... (EGR Pressure Feedback Sensor)
was the same as ......... EBP (Exhaust Back Pressure Sensor) because they sure look the same
Old Sep 22, 2011 | 07:24 AM
matty169's Avatar
matty169
yes
Same thing
Old Sep 22, 2011 | 09:43 AM
big dirty's Avatar
big dirty
Thanks...
was over on www.tousleyfordparts.com website and seen that it was the same name/description as it was on Rock-Auto's site.
Thanks again !!
Dave
rattleNsmoke
Jan 26, 2012 08:13 AM
ALdieselfan
Jul 14, 2007 05:50 PM
ron's power stroke
Oct 6, 2006 09:37 PM
oldbird1965
Jun 12, 2006 12:53 PM
flextone444
1997 - 2003 F150
Sep 4, 2004 11:22 AM
