ok blew my egr cooler last week so im forced to dive into head gaskets and studs a little quicker than i wanted. my question is i have 1 or 2 sticky injectors and i went the rev-x route before but im ready to address the problem correctly now. new injectors, yay. looking for input on where to buy from and also looking at going 1 size higher. keep in mind i tow ALOT with my truck but also know when to take it easy. truck is 05 f550. pensacola diesel has +40 or 70 injectors for 1879.
If so, then you are looking at buying them from the most consistent injector company out there. Consistently crappy, so get used to changing them.
++++++++1
Do NOT buy them from Pensacola diesel unless you want to get LOTS of practice changing injectors. This is one thing where quality really counts so choose wisely. Is there a particular reason you want to go with oversize injectors? The stockers provide LOTS of fuel and pulling power with the right tuning.
No real reason. Just figured one size up wouldn't hurt. Thanks for the heads up on pensacola. Any other places you would recommend. I think im just gonna stay stock on injectors. I've got a sct tsx comun so that should do the trick for tuning
Ford remans are $220.00 each. Best way to go hands down.
Agreed.
If you have time shop Ebay. You can pick up Motorcraft injectors "cheap" if you work at it and not have to send back cores. I was lucky and got a whole set for $1250 shipped to the house.
