Top heavy 6inch
Old Sep 22, 2011 | 06:13 PM
  #31
95stepside's Avatar
95stepside
Originally Posted by Edgethis
As long as you don't go through mud/deep snow slowly you should be fine. Once your momentum stops you will start to get stuck, you'd be a bit better putting a mud terrain on in winter. At least on the back. You're gonna get the big truck mentality (don't we all) and get stuck without tread.
I disagree. Mud terrains suck on ice and slick roads. Too much tire on the road
Old Sep 22, 2011 | 06:24 PM
  #32
Edgethis's Avatar
Edgethis
Most all tires suck on ice unless they have studs or chains
Old Sep 22, 2011 | 06:53 PM
  #33
95stepside's Avatar
95stepside
True, but my worn out wrangler rt/s were better in the winter than my brand new MTs
Old Sep 22, 2011 | 07:50 PM
  #34
big-ugly's Avatar
big-ugly
I'm curious to see how my duratracs do in the snow this winter. They have the mountain/snowflake symbol for winter weather, so should be interesting.
Old Sep 22, 2011 | 08:20 PM
  #35
Edgethis's Avatar
Edgethis
I've run lots of trucks with Wrangler MTRs through deep mud, deep snow and over packed snow/ice. They handled very well I thought for a mud tire.
Old Sep 22, 2011 | 10:31 PM
  #36
GoinBoarding's Avatar
GoinBoarding
When the white stuff flies, please let everyone know how they do! I've heard they're awesome..
Old Sep 23, 2011 | 08:40 AM
  #37
big-ugly's Avatar
big-ugly
Will do. So far I have been pleased in every way with these tires. In deep mud they dig great, on the road they are fairly quiet and ride smooth. For about the first 500 miles they threw rocks really bad, but after they wore in they stopped doing that. If they perform the way I expect them to this winter, I am definitely going to putting these on all my trucks.
Old Sep 23, 2011 | 09:47 AM
  #38
ItsAFord55's Avatar
ItsAFord55
Originally Posted by Nickk97tml
I believe someone mentioned to get mud tires for the winter, I disagree. First snowfall with my 33's and my stopping distance was about a mile lol.
Heres 235's on a 4 inch lift not the 6 I got later. I dont know the Imperial conversion of 235's into inches but correct if Im wrong 235's are a bit smaller than 31's.
do you have any pics of your truck with the 6 inch and the 235s?
Old Sep 23, 2011 | 10:46 AM
  #39
Nickk97tml's Avatar
Nickk97tml
well if you wait till early november I would take the pic but I just got it to 6 inches this summer lol
Old Sep 25, 2011 | 03:19 PM
  #40
ItsAFord55's Avatar
ItsAFord55
is there any axle swaps that have 4.10s and posi?
Old Sep 25, 2011 | 04:47 PM
  #41
big-ugly's Avatar
big-ugly
Yup, axles with those gears and limited-slip diffs. If you're doing an axle swap you might as well make it a D60, good luck finding one for under a grand though. You could check out the 4x4 and Offroad section. Those guys could help shed some light on what you're asking us.
I suppose you could find a TTB front axle and a rear end to match it, which would be easier, and cheaper. But still hard, and expensive.
EDIT: Forgot your truck is a 4x2, sorry. You will only need the rear end, which wouldn't be that bad to swap out, and reasonable to find. I believe I read somewhere that lightnings were the only ones that came with 4.10's and limited slip for our trucks, otherwise you were stuck with either 3.08 or 3.55 I'm getting too tired now to look for the thread I read that in, but that should help you narrow your search quite a bit.
Old Sep 26, 2011 | 09:34 AM
  #42
sling94's Avatar
sling94
some explorers came with 4.10s, mainly the explorer sports irrc. but you cant swap the whole axle
Old Dec 19, 2011 | 10:50 PM
  #43
ItsAFord55's Avatar
ItsAFord55
would you happen to have any pics of your truck with 6 inch and 31s yet ??
Old Dec 19, 2011 | 11:57 PM
  #44
minnesotafisherman's Avatar
minnesotafisherman
My truck has Moog CC844 (F250) coil springs up front, to level out the 2wd rake, and a 3 inch body lift sitting on 31's in my sig picture. It currently has 235/75/15 WinterForce tires on for the winter.
If you want to lift your truck, then lift it. Don't let the negative comments from people on this forum bring you down. It's your truck and do whatever you want to. I would suggest getting the 6 inch lift, as the 4 inch would probably just bring you close to a stock height 4x4, maybe a bit higher. My 3" lift makes my truck sit like a 4x4 now, but I still want just a little more height to it. Although the downside to a 6" is you need bigger tires to accommodate all of the extra wheel well space vs. the 4" lift which would be fine with 31's. All in all, it's up to you.
Good luck.
Old Dec 20, 2011 | 12:20 AM
  #45
Nickk97tml's Avatar
Nickk97tml
wow haha I never would have thought you wuld remember! its a lot like minnesota fisherman's. Havent washed it in a while, havent even started it in like a week either lol been neglecting it. Remember, its lifted 6 inches in the front, 3 inches in the back, makes it perfectly level for me
