Tie rod ends???
Old Sep 20, 2011 | 07:35 PM
1912barry's Avatar
1912barry
Tie rod ends???
I cant seem to figure out what tie rod ends I need. Autozone has different ones depending on serial numbers, one is for M00001 and M00002, this is for both inner and outer, It also say by the last 6 of the vin code. Can any one tell me how to figure this out with my vin#?
Old Sep 20, 2011 | 11:05 PM
elgemcdlf's Avatar
elgemcdlf
I think they are tuggin your leash. What year is your truck and model?
Old Sep 21, 2011 | 05:47 AM
1912barry's Avatar
1912barry
Its a 1970 F-100 4x2. All the parts stores I called yesterday say the same thing. The tie rod ends that are on my truck now must be too long, I have them screwed in all the way and bottomed out and still have 3/4 in toe in. I may just cut them down so that I can get this thing alligned.
Old Sep 21, 2011 | 08:00 AM
elgemcdlf's Avatar
elgemcdlf
Well when I went to looking sure enough it came back with "up to ser no ..." I am not a parts guy so maybe Number Dummy will chime in on this one. I know Ford seems to like the years that end with 0 to make transitions and usually single year items. Example: I had a 1980 4x4 and was shopping for gears. It is the first year for that body style and I was told it was the only year in the independent front suspension that had reverse rotation. I have a '70 and have run into '70 only items when looking around.
Old Sep 21, 2011 | 02:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The serial number is the last 6 digits of the VIN / I don't give a rats behind what autoparts stores claim, because the M serial numbers do not apply to 1970.
1970 F100/750 serial number range: G30,001-J70,000.
1971 F Series Trucks serial number range: J70,001-M30,001.
1972 F Series Trucks serial number range: M40,001-Q80,000.
There is no before/from certain serial numbers listed in the truck parts catalog inre to tie rod ends.
The I-Beam ID numbers must be known to get the correct parts for 1971.
C5TZ-3A130-A .. Right Tie Rod End / Obsolete
C5TZ-3A131-A .. Left Tie Rod End / Obsolete
Applications: 1965/70 F100/250 2WD / 1971 F100 2WD, 1971 F250 2WD with 12 1/8" x 2" drum brakes.
Use with I-Beams marked C8TA-3008-B (right), C8TA-3009-B (left).
D2TZ-3A130-A .. Right Tie Rod End / Obsolete
D2TZ-3A131-A .. Left Tie Rod End / Obsolete
Applications: 1971 F100 2WD-Use with I-Beams marked D2TA-3008-DA (right), D2TA-3009-DA (left) / 1972/74 F100 2WD.
This truck is 41 years old, prolly has had multiple owners, so who knows if the parts are original or have been swapped in from another truck?
The I-Beam changeover occurred in 1971. Look on your trucks I-Beams for the cast ID numbers. If different from the above examples, post what the numbers are.
Info sources: 1964/72 Ford Truck Parts Catalog & 1973/79 Ford Light Truck Parts Catalog.
Old Sep 21, 2011 | 05:07 PM
elgemcdlf's Avatar
elgemcdlf
As to Number Dummy's response I also came across parts that had no reference to ser no. So I found both ways but tend to side with NumberDummy. Well not tend, I just do. It was the first I had ever heard of using ser no for front end parts. I turned a wrench for 12 yrs & had never heard of such a thing. I am guessing their parts books do not specify by year and have them grouped. The M designation that you and Number Dummy refer to as he said was in '71 so your answer would be before.
Old Sep 21, 2011 | 05:11 PM
1912barry's Avatar
1912barry
Number Dummy,
Where on the I-beams will the casting numbers be? I will look and report back tomarrow.
Old Sep 21, 2011 | 10:15 PM
NumberDummy
You aren't siding with me, you are siding with FoMoCo. The info I typed was taken directly from the 1964/72 Ford Truck Parts Catalog.
The cast ID numbers on I-Beams are EZ to see.
trav69187
Nov 10, 2007 03:58 PM
53f100ala
Jan 2, 2007 01:03 PM
zach1877
Aug 1, 2006 02:35 AM
Kemicalburns
Apr 4, 2006 04:57 PM
