locating tie rod
Old Apr 4, 2006 | 09:48 AM
Kemicalburns's Avatar
Kemicalburns
locating tie rod
my uncle has a 76 4x4 crew cab f250. its running the heavy duty D44 upfront and is having some trouble locating the proper length tie rod. i guess this was a 2 year only run and is different then other setups. were do you guys get your steering parts from. he has tried napa, broncograveyard and some other place back east with no luck. all were incorrect parts. they just ordered from LMC hoping its the correct one.
thanks
Old Apr 4, 2006 | 09:56 AM
1975Ford's Avatar
1975Ford
Try National Part Depot, you will need to look and write down the VIN number
Look under the steering section of the catalog.
------ buck ------
Old Apr 4, 2006 | 10:47 AM
Mil1ion's Avatar
Mil1ion
I have a book right here in front of me.
76-77 Crew Cab tie rod end = Sealed Power part #802-2063L
So,
What is the axle rating,
What is the date of build (last 6 digits of Vin#)
Power sterring ? and what type ?
Old Apr 4, 2006 | 11:17 AM
Kemicalburns
yes it does have power steering. the tie rod swings front to back to turn the front end if that helps at all. I emailed my uncle to get the other info for you. by the way what book are you looking in?
Old Apr 4, 2006 | 12:02 PM
Amtek's Avatar
Amtek
That would be the "drag link"
Old Apr 4, 2006 | 12:12 PM
Mil1ion's Avatar
Mil1ion
I have a sealed power catalog.
You can look at www.rockauto.com for numbers as well.
It is best when asking questions to supply all necessary info at the time.
Old Apr 4, 2006 | 03:35 PM
1975Ford's Avatar
1975Ford
Is the drag link worn or is the control valve worn?
----- buck -----
Old Apr 4, 2006 | 04:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
Nomenclature is everything...
