Injector Question
Old Sep 20, 2011 | 11:29 PM
iduger's Avatar
iduger
Sorry epic did not read upper posts im sure there is someone in oklahama that can help. You are correct in that if you do not have correct voltage from batteries, ficm voltage will be affected you might have a bad alternator and of course bad battery. Autozone can check batteries and charging system. That would be where i would start.
Old Sep 21, 2011 | 05:44 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by cheezit
O mock me if you will
I actually wasn't mocking you. It was really meant as a compliment. I just wanted to see if my thinking was correct before coming out in the forum with it. To me it's just a weird diagnosis. Dead injectors and overfueling injectors on the same bank sounds more like someone not reading the CB test correctly. I was initially thinking an injector leaking into the fuel rail.
comsupany
45
May 19, 2016 11:07 AM
TheCurtster
Jan 20, 2014 03:01 PM
2006powerstroke90
Aug 29, 2011 04:50 AM
aocabrown
Nov 30, 2008 08:00 PM
wolfe1104
21
Mar 5, 2008 09:21 PM
