Hot wire
Old Sep 20, 2011 | 01:17 PM
Sheryle's Avatar
Sheryle
Hot wire
I have searched and can't find the answer to my problem. I want to hard wire my Escort through the overhead console. Finally got a blend mount for the SG II and the RD. I tried my test light and finding a ground is a challenge. I need the color of the wire that is a switch(on/off with the ignition) wire.?????. If not that can you lead me to a grounding spot reasonably close to the console. Thanks in advance.
Old Sep 20, 2011 | 02:50 PM
jh818's Avatar
jh818
How about the chasis? Any exposed metal on the body of the vehicle is the ground. Just make sure there is no paint over the metal.
Old Sep 20, 2011 | 02:54 PM
jh818's Avatar
jh818
As far as the switched hot wire, look for an empty slot in the fuse box that is switched to the ignition and fish the wire behind the dash, up the pillar, and underneath the headboard on the roof to the console.
Old Sep 20, 2011 | 08:11 PM
Sheryle's Avatar
Sheryle
Hot wire
I appreciate your input. I was trying to avoid running another wire from bottom to top. That is what I may end up doing and it is no big deal. Thanks.
Old Sep 20, 2011 | 08:24 PM
william_04_x's Avatar
william_04_x
I hardwired my V1 up above the mirror and fed it with an Add a Circuit. There are fuses in the CJB that are switched by the Acc. Delay Relay. There are factory grounding points behind the big cover under the column(look above the "CPU-01" box in the pic). Running a pair of wires from the headliner to under dash is a cinch. Good RD's are expensive and worth doing it right. This is the best option IMO.
Old Sep 20, 2011 | 10:34 PM
jasonodsky's Avatar
jasonodsky
You should be able to pull both switched power and ground from the message center on the console even if you don't have the message center. The connector you're looking for is at the front, it is big and gray. See the second pic.
Ground will be pin 1 pink/orange and 12v will be pin 7 light blue/pink. The pin numbers are from the message center female side of the plug and if I remember correctly, the number are opposite on the other connector but the wire colors are correct. Just use the trouble light to confirm.
You can disconnect the message center and everything will still work. That will give you easy access to the pins for testing.
Pinout from message center:
The connector:
Old Sep 21, 2011 | 07:20 AM
Sheryle's Avatar
Sheryle
Thank you JASONODSKY. That is the information I was looking for.
Old Sep 21, 2011 | 02:46 PM
jasonodsky's Avatar
jasonodsky
Happy to help. I tapped it to run a backup camera and monitor up there. Have fun with the project.
Old Oct 3, 2011 | 10:12 PM
jasonodsky's Avatar
jasonodsky
Sheryle, Any luck finishing the project?
clhart426
Sep 7, 2010 08:44 PM
buckshot047
Jun 1, 2007 02:53 PM
GOTH_TRUCKER
Electrical Systems/Wiring
Sep 6, 2006 04:40 PM
mcne2026
Jan 10, 2006 01:24 AM
