Anyone up for a challenge??
Old 09-20-2011, 08:45 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
Heres what I have. I need a heater core whose dimensions of the core itself are 7 7/8 x 2 1/2 x 7 3/4. I do not care about the tanks. I will be soldering on different ones. Heres the kicker.... They cannot be aluminum (because I have not figured out how to solder to that) and they need to be cheap. I have been looking for a while and no luck. I have seen cores for like 80s pickups for instance in the 20 -30 dollar range which would be great. If you are bored HAVE AT IT!!!! THANKS!!
Old 09-21-2011, 07:17 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
If you still have your old one, you could try taking it to NAPA and see if they can match it up...
Old 09-21-2011, 09:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Believe it or not, I found a comprehensive list of heater cores on a site for high-performance computers. They apparently use them to cool off "hot" computers. It's a spreadsheet, two of them actually, one tells all the dimensions, the other cross-references from the FEDCO model number to a make and model of car that it's used on.
There are lots of them near the size you want, none exactly the same, and most are thinner (which may not be a problem). I'll send you the native XLS's off-line.
File Type: pdf
File Type: pdf
dohc_chump
27
09-28-2010 03:04 PM
J.McConnell
03-08-2009 06:46 PM
Mudman
03-25-2007 05:08 AM
John - NNY
24
03-20-2007 04:29 PM
GreatNorthWoods
02-22-2004 07:10 AM
Quick Reply: Anyone up for a challenge??
