Heater core replacement size issues
When I bought the truck (85 F250 RWD 6.9 Diesel Extended Cab) the heater core was bypassed. Since I live in Southeast Texas, I didn't figure I'd need heat but realized on a cool humid morning that having no defroster is a pain. I took out the old heater core (truck has A/C, standard output) and went to the autoparts store for a replacement and they came back with an aluminum core that looked like it would fit. Went home and tried to work it into the housing behind the glovebox but it would not fit. The original core had a curved compartment on the top but the replacement had a square compartment which would not fit into the housing. About 1/4" off of the top left corner was in the way (looking from the passenger seat toward the front of the truck).
I went to every autoparts store I could find and all of them had the aluminum square top cores. The online catalogs and in-store catalogs showed the new cores to look identical to the original, but every box had the aluminum cores that would not fit.
I don't want to force the thing in there and damage it, but I do want heat. I'm thinking that maybe if I remove the entire housing assembly I'd be able to get it in there, but I really don't want to go through all that work and have the core still not fit. Some pictures for reference are below.
This is all I can find locallyI've seen some sites that offer the original looking cores (from their pictures) but I'd rather put eyes on it before buying it online and paying more (with the possibility that it will not be the right kind). Help?
Both were brass at that time, but it looks like O'Reilly's has gone to the aluminum ones...
