motor oil in fuel filter? NO START
09-22-2011, 04:21 PM
on
I would lean more to lack of maintenance or poor. Alot of my customers are contractors they normally dont come in till something is broke....
09-22-2011, 07:18 PM
Sounds like a worn poppet issue..
09-22-2011, 08:53 PM
on
READ#29 Took No 1 injector swapped holes it was fine. Put known good injector in number 1 hole no fire. Yes wires are OK
09-22-2011, 09:01 PM
Quote:
Originally Posted by
sleepyhead416
Thanks for pointing that out .. It sounds like you all ready have the answer . If the problem didn't move it can only be one thing
Good luck ..
09-22-2011, 09:12 PM
09-22-2011, 09:17 PM
Oil goes to all four can't stop it , fuel goes to all four can't stop it .......OP needs to check the wires again.. But what the hell do I know.
IDM or PCM won't shut down one
09-23-2011, 04:23 AM
on
Going to do the IPR cleaning/rebuild today, along with oil change. Not my truck so who knows the last time it was changed? (Looks VERY THICK)
09-23-2011, 01:56 PM
on
Keeping fingers crossed Change oil & should be ready to fire up.
09-23-2011, 03:55 PM
on
Well if fired up EVEN without glow plugs. Still No1 cyl would not fire let it run for 15min All of a sudden no1 started firing w/oil out of spurts (was none before) Seems like it has to get temp up to get number 1 to fire why ?????
turbodiesel13
02-18-2016 07:13 PM
joshparton
10-21-2012 02:26 AM
jayc3169
08-19-2012 11:40 AM
philwaters
04-04-2010 08:26 PM
bootsgmc
06-30-2008 12:32 PM
