charging problems
Old Apr 6, 2003 | 04:14 PM
F150daniel's Avatar
F150daniel
charging problems
My ammeter goes crazy when i'm on the gas it discharges, keeping speed on level ground it jumps back and forth, and off the gas it charges. sometimes it works fine, I think its a bad connection but i havn't found one.
Old Apr 6, 2003 | 05:56 PM
woppini's Avatar
woppini
charging problems
Check your output at the battery and alternator with a known good digital volt meter at differant engine rpm's. If you still see the voltage erratic, check the regulater, or my guess is, you have a slipping belt
Old Apr 30, 2003 | 10:20 AM
Bern_F150_4x4's Avatar
Bern_F150_4x4
charging problems
I'd agree with the slipping belt diagnosis, but I've seen some funy business with engine grounds too. Check that the engine is properly grounded with a suitable sized cable to the cab and frame.
Olds69442
6.7L Power Stroke Diesel
Dec 23, 2012 06:17 PM
Rudude8960
1983 - 2012 Ranger & B-Series
Feb 1, 2009 01:19 PM
greagin
37
Feb 10, 2008 07:11 PM
yellowboy
Car/truck Buying Advice
19
Jun 3, 2007 09:32 PM
BattleBotsJudge
Oct 30, 2003 03:04 PM
