Stupid Question
Old Sep 19, 2011 | 09:33 PM
bearman113's Avatar
bearman113
Alaska Chapter ******
Stupid Question
Will a trickle charger charge both batteries, when connected to one battery?
Old Sep 19, 2011 | 10:03 PM
ff1210's Avatar
ff1210
Yes it will cause they are connected together.
Old Sep 19, 2011 | 11:03 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Yes, because the batteries are connected in parallel, if they were connected in series then a 12 volt charger would not work.
Old Sep 19, 2011 | 11:20 PM
snakedoc's Avatar
snakedoc
X3^.......
Old Sep 20, 2011 | 12:51 AM
slim613's Avatar
slim613
x4
and there are no stupid questions at FTE bud unless ur trying to make ur truck smoke
Old Sep 20, 2011 | 03:00 AM
hotroddsl's Avatar
hotroddsl
There are no stupid questions!....
Only Monty's stupid answers!....
Jim & fat stupid Monty
Old Sep 20, 2011 | 12:43 PM
Brother Les's Avatar
Brother Les
Yes, they will both charge together, but remember that they may not 'hold' a charge together. Meaning when charged they will both show the same voltage. But if you charge them seperately (unconnect both and charge seperately) and then check the final voltage, it is a good chance they will be at different levels. But.... when putting both back on the truck and connected together, the 'lowested' battery (it may have a cell going bad) will pull the other batt down closer to its' level.
Old Sep 20, 2011 | 12:57 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Sure, but it will be like filling a bathtub with an eyedropper....just sayin
Old Sep 20, 2011 | 02:27 PM
bearman113's Avatar
bearman113
Thanks, the reason I asked is because it looks like I'm going to have to spring for two new batteries and I don't want them to freeze up this winter as I won't be driving the truck that much
Old Sep 20, 2011 | 11:27 PM
jc8825's Avatar
jc8825
Originally Posted by slim613
x4
Yes! Reps to you.
jlillie
Feb 2, 2016 03:34 PM
cbrown9064
Dec 3, 2013 08:56 PM
Olds69442
6.7L Power Stroke Diesel
Dec 23, 2012 06:17 PM
guitarpicr
Nov 4, 2007 08:42 PM
TransplantX
Sep 10, 2006 12:02 PM
