Injectors
Old Nov 13, 2013 | 01:01 PM
Kingkoopa's Avatar
Kingkoopa
Injectors
Has anyone here used the sniper injectors? they are 170cc. for the 7.3 obs they are right at $1000 and rosewood stage 2's are about $1600 just wanted to know if anyone had any experience with the brands?
Old Nov 13, 2013 | 01:55 PM
DIYMechanic's Avatar
DIYMechanic
There was a conversation going on about those injectors a week or two ago and from what I have heard there are mixed reviews of them. What size are the nozzles? Just the fact that they're 170 cc doesn't mean much. If they have stock size nozzles on them you have more or less a Stage 1 injector (160cc). If they're bigger nozzles, keep in mind that you're likely going to need a bigger HPOP as well to fully utilize the injectors.
Old Nov 13, 2013 | 02:05 PM
Ford4Life7.3's Avatar
Ford4Life7.3
They have a checkered reputation it seems. Some people are pleased, some say they had problems or customer service was less than ideal. No one here I know of runs them, but i know that I've seen talk of them on Powerstroke.org and oil burners before.
Old Nov 13, 2013 | 02:22 PM
DIYMechanic
And just for the record, if you just want some cheap injectors, Jim (Rosewood) will build you a set of "budget builds" for less than that so long as your old ones aren't completely bombed.
Old Nov 13, 2013 | 02:48 PM
Kingkoopa's Avatar
Kingkoopa
well i was looking to get the rosewood 2.5's. my bad on the first post the sniper injectors they are 100hp over stock if that helps. i checked out the rosewood website and it doesnt say there is a budget build for the stage 2.5's
Old Nov 13, 2013 | 02:57 PM
DIYMechanic
There's not a budget build for 2.5's because they include all new parts. The fact that Sniper rates their injectors by HP and not the cc rating tells me all I need to know about that builder. Let me guess...he sells injectors for Cummins engines as well? With the right tunes and supporting mods you can get close to that out of a set of Rosewood stage 1's pretty easily. If you're looking at 2.5, remember that you're going to need to spend some serious coin on supporting mods as well (e-fuel, gauges, custom tunes, HPOP, Turbo, Exhaust, Intake, and a built transmission if you have an auto, etc.). My .02 if you're going to spend that much on a mod, spend the extra $$ and do it right the first time. Cutting corners on modding a PSD is going to leave you disappointing with a busted truck.
Old Nov 13, 2013 | 03:22 PM
Kingkoopa's Avatar
Kingkoopa
ok that helps a lot. i already have a ts 6 pos/chip, 3"dp/4"exhaust, and afe intake. what do you recommend for the turbo upgrade? and what about the intercooler?i see a lot for upwards of $1000 is that the standard or is there a more cost effective way?
Old Nov 13, 2013 | 07:35 PM
DIYMechanic
Yeah I forgot to put an IC on that list too. What are you seeing for upwards of $1000? An IC kit? You can put your own IC kit together for about half that. Use an IC out of a 99+ 7.3 or get one from a 6.0 then buy or make the pipes and buy the boots. For the turbo upgrade it just depends on how big a set of injectors you're going and what you want to use the truck for. For stage 1's the stock turbo is sufficient but an S366 turbo kit is an upgrade and will work nicely with a set of 2's. Bigger than that and you really should look at a T4 frame turbo and there are quite a few to choose from for that.
How much you spend on this stuff is largely determined by how much you want to source, build or piece together yourself. If you want to just buy everything in a "kit" you can do that too, but you pay a little more.
Old Nov 13, 2013 | 09:32 PM
fordpride's Avatar
fordpride
With 2.5's your stock turbo will hate its life.
What's your power goal and what do you want to do with the truck?
Old Nov 13, 2013 | 09:42 PM
fordpride's Avatar
fordpride
With stageII or bigger you really need to do head studs, valve springs, pushrods, hpop, turbo, clutch(if 5speed) built trans (if auto)
Old Nov 14, 2013 | 09:50 AM
Kingkoopa's Avatar
Kingkoopa
im looking for around 400hp to 450hp. an everyday driver that i can still run on the 1/8 mile on the weekends. i just want something fun you know thats still practial. On the turbo i have seen this thruster 2 turbo on some other forms is it any good?
Old Nov 14, 2013 | 12:26 PM
fordpride's Avatar
fordpride
All it is is a stock turbo with a ungraded compressor wheel just like the D66
To get that power level you'll need to go to a T4 setup with a S300 or S400 series turbo
fordpride's Avatar
fordpride
Old Nov 14, 2013 | 02:56 PM
Leemakesmepee's Avatar
Leemakesmepee
Do you have any sites where they sell the pipes? or the spyder i cant find those parts any where.
Old Nov 14, 2013 | 05:57 PM
blageurt's Avatar
blageurt
You can find the Spyder anytime ........anywhere........ on Ebay...Just depends how much you want to pay......
