Sponsored by: Real Truck
Superduty Wheels
Old Sep 19, 2011 | 12:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Superduty Wheels
What year did they change the offset? I'm looking at a set of 06 wheels for my 2002.
Old Sep 19, 2011 | 01:18 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
2005, with the coil springs on the 4wds
Old Sep 19, 2011 | 01:21 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Is the offset about 2" same a the later models?
Old Sep 19, 2011 | 01:25 PM
texastech_diesel
Token Redneck
IIRC, the post-05 wheels run about an inch or an inch and a half narrower track width on the inside, the youtube excursion guy used 2" spacers to clear them on his Ex. I don't have a subscribed thread to pull the specs out of real fast, but there's a couple good ones if you search.
spinella's Avatar
spinella
yes...1.75"
Old Sep 19, 2011 | 01:32 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thanks. I'm on my phone and FTE mobile has a search worse than the normal one if you can imagine!
Thanks for the answers guys.
So a 2" spacer would work fine? It's just an idea I'm mulling around
Old Sep 19, 2011 | 01:45 PM
spinella's Avatar
spinella
2" spacer would make it so you dont have to cut your original wheel studs down.
Old Sep 19, 2011 | 01:52 PM
raidscsi's Avatar
raidscsi
I thought using the spacers did 3 things, keeps the tires from hitting things, returns the original track width of the vehicle, and most importantly keep the center of the tire properly located so that when you turn the tire it spins on a vertical axis rather than roll in a arc.
Also neat, Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
johnday
Ford Truck Parts for Sale
Apr 29, 2016 06:00 AM
a4x4nutt
Dec 2, 2009 07:44 PM
dixiemudder04
2004 - 2008 F150
Nov 11, 2008 02:04 PM
spr1516
Oct 20, 2008 12:46 PM
