1953 OHV V8?
Old Sep 19, 2011 | 12:36 PM
kinabro's Avatar
kinabro
1953 OHV V8?
I have a 1953 "anniversary" F-1 pickup with what appears to be a 272-292-312 OHV engine. It appears to be original. Is this possible...maybe built near the end of the run to explain no flathead?
Old Sep 19, 2011 | 01:51 PM
Randy Jack's Avatar
Randy Jack
If you do, in fact, have a 1953 Anniversary Ford pickup, it is an F-100, not an F-1.
No 1953 (car or truck) came with a Y-block. It was the last year of the flathead.
Your truck is unlikely to be "original". Now you just need to figure out what you actually do have.
BTW, welcome to FTE.
Old Sep 19, 2011 | 02:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Since '54-on used the Y-block, it would be easy to use a '54-on engine, bellhousing, mounts, radiator, etc if a flathead died. It would literally fit like it was made for it, if done right.
Old Sep 19, 2011 | 09:04 PM
HT32BSX115's Avatar
HT32BSX115
Both politicians and diapers need to be changed often, and for the same reasons!
AND they're more like the disposable kind and should just be thrown away and replaced!
Old Sep 19, 2011 | 09:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When Ford introduced OHV V8 engines in 1954 Ford/Merc's, they had the same cubic inches as Flatheads.
1948/53 Trucks, 1949/53 Ford Passenger Cars: Ford flathead V8: 239 cid / 1954 Ford OHV Y block 239 cid / 1949/53 Merc flathead: 256 cid / 1954 Merc OHV Y block: 256 cid.
1903-1953 Golden Anniversary: The horn buttons used on 1953 Ford Trucks, the horn button/horn rings used on 1953 Ford Passenger Cars are so marked.
It's real EZ to swap horn buttons, so the truck may be a 1954/56 w/a 1953 horn button. AFAIK, there is no other part marked 1903-1953 Golden Anniversary on 1953 Ford trucks.
Old Sep 21, 2011 | 08:11 PM
Dale Fairfax's Avatar
Dale Fairfax
Did anybody ever wonder why the '53 trucks were the ONLY Ford vehicle with the Flathead V8 mounted the way it was-single yoke type mount in the front; two side mounts at the bell housing. All very similar to the the Y-Block mounts of '54. I've always felt that the new truck design for '53 was meant to have the new engine but material allocations in effect for the Korean war delayed Ford's plan. Last minute changes resulted in the odd engine mounting system.
Old Sep 21, 2011 | 10:03 PM
52 Merc's Avatar
52 Merc
From what I've read, Ford's intent was to have the Y-block OHV engine done in time for the 50th anniversary in '53. It wasn't ready and they had to go with plan B at the last minute. That's why there's so many strange, one-off parts.
Old Sep 22, 2011 | 06:54 AM
4tl8ford's Avatar
4tl8ford
1949/53 Ford flathead V8: 239 cid / 1954 Ford OHV Y block 239 cid / 1949/53 Merc flathead: 256 cid / 1954 Merc OHV Y block: 256 cid.
Bill - That's 1948/1953 Ford Flathead (Trucks) V8: 239 (NOTE: 1954 in Canada)
Old Sep 22, 2011 | 07:59 AM
NumberDummy
Correctamundo. I edited the post.
kens65fb
Jun 17, 2017 12:09 AM
jgc2521
13
Oct 17, 2005 01:37 PM
weege
May 23, 2002 05:51 PM
pops
Nov 8, 2000 01:17 PM
