Ok... weird problem. Truck doesn't want to turn over when engine has been previously run. It will turn over right away when cold, but after a drive, if I try to restart the vehicle, it barely turns over once and then freezes... and the lights in the vehicle go really dim until I release the ignition. Replaced battery, starter, and same thing. Solenoid is fairly new too. I ruled out "timing issues" for hard starting, since I can't even get the thing to make a single revolution. I have tried jumping solenoid, and get the same thing. What is wrong with my baby?
