1978 - 1996 Big Bronco
Changing oil??
Old Apr 3, 2003 | 03:03 PM
VIBR8R's Avatar
VIBR8R
Changing oil??
I haven't had my bronco long enough yet to change the oil in it. However, I plan on doing it today. How many quarts does the 302 hold?
Old Apr 3, 2003 | 03:37 PM
Kemicalburns's Avatar
Kemicalburns
Changing oil??
6, you might get your self a chiltons or haynes manuel. will help for future projects. I would start with 5 , start the rig so the oil gets moved around good then check it. if it needs more then add till full
good luck
Old Apr 3, 2003 | 04:49 PM
VIBR8R's Avatar
VIBR8R
Changing oil??
thanks kem.
Old Apr 3, 2003 | 05:19 PM
AlM's Avatar
AlM
Changing oil??
vib,
You'll find that the oil filter will leak a bunch when you take it off and spill oil all over, so have big rags ready.
Old Apr 3, 2003 | 10:29 PM
ba 302's Avatar
ba 302
Changing oil??
I like to run the vehicle up to running temp then lossen off the oil filter just a bit befor draining the pan. also it depends on how many miles it has on her it not a bad ideal to put so slick50 in her as well it maks a big differents with you oil presurer.
Old Apr 6, 2003 | 07:01 AM
Sudsrat's Avatar
Sudsrat
Changing oil??
Hey ba 302,
Heard alot about this slick 50 stuff a few years back.Would it be good for my '91 w/126k on her? And how does it benefit the oil pressure?
Sudsrat
Old Apr 6, 2003 | 07:21 AM
scionti 94's Avatar
scionti 94
Changing oil??
In my '94 Bronco, 351W, I only use Valvoline Max-Life. It has 108,000+ miles. Keeps the gaskets from hardening and has a small amount of cleaning agent in it. First couple of times I used it, the oil became dark after a thousand miles or so. Since then, whenever I check the oil, the residue on the stick is a lot cleaner. I have never used additives, just always used a good quality oil. Strictly dino, never got caught up in the use of synthetic. Would not recommend a synthetic with your mileage. You may see quite a bit of leakage develop. Others out there have good opinions. Hope they jump in and give you some insight. You have chosen a great site to get started. Before I ever do any work on my Bronco, I bounce it off all the help you get from this site. Good luck on your project.
Old Apr 6, 2003 | 08:20 AM
alanscott's Avatar
alanscott
Changing oil??
Read through this thread on oil additives before you decide.
https://www.ford-trucks.com/forums/s...threadid=87131
Old Apr 6, 2003 | 08:48 AM
scionti 94's Avatar
scionti 94
Changing oil??
Good advice allanscott !!!
Old Apr 6, 2003 | 09:04 AM
Sudsrat's Avatar
Sudsrat
Changing oil??
DITTO!
Old Apr 6, 2003 | 10:08 AM
georgedavila's Avatar
georgedavila
Changing oil??
To save your rags and avoid a mess, place a pan under the oil filter area and poke a hole in the filter with screwdriver to let it drain before removal. When you replace it, fill the new oil filter 3/4 full with new oil before screwing it on. That'll give you almost immediate oil pressure on starting the engine.
As allenscott points out, investigate additives before you use them. Most are a polymer base which will eventually solidify behind your rings and in your valve guides.
I'd recommend using Motorcraft or Delco oil filters. Fram oil filters sold by most discounters have a cardboard pressure retention valve and it will eventually leak, allowing the engine oil to drain back into the pan resulting in dry bearing starts.
Old Apr 6, 2003 | 12:12 PM
dun4791's Avatar
dun4791
Changing oil??
6 quarts FL-1A with a little poured in first 5W 30 in winter 10W30 in summer no synthetic
Old Apr 6, 2003 | 01:23 PM
alanscott's Avatar
alanscott
Changing oil??
Remember the oil filter study that used to be floating around? I found a mirror of it, it's still about 90% complete.
http://home.planet.nl/~Jennit/Techni...OilFilters.htm
Bordermen
20
Sep 28, 2019 03:48 PM
ItsAFord55
Aug 6, 2011 11:50 PM
Adam0331
40
Aug 31, 2008 09:09 AM
davidwruth
May 13, 2003 02:57 PM
pcmenten
Oil & Lubrication
Feb 6, 2003 06:20 AM
