Rocker arm re-install problem
Old Sep 18, 2011 | 01:59 PM
xsportplyer's Avatar
xsportplyer
I just replaced the head gaskets and studs on my 04 F-350 6.0 PSD. When I was rebuilding the passenger side I noticed there was pressure on the rocker arm in the front of the engine. After looking a little closer I realized that push rod was slightly higher than the others. I didnt see any debris in the engine when I put the head back on, and cant get that push rod to go down any further. The is a decent amount of pressure across the rocker arm and down on the springs. I cant even wiggle it slightly side to side like the rest of them. Any Ideas? Hopefully this can be solved without pulling the head again.....
Old Sep 18, 2011 | 05:21 PM
cheezit's Avatar
cheezit
try turning the egine over by hand yet? there is an issue with lifters pumping up and getting stuck. search function would have found something on this.
Thinlizzy13
Oct 11, 2015 03:47 PM
82fordowner
Mar 21, 2015 10:27 AM
revans9295
Mar 30, 2013 08:08 AM
FallstonYJ
19
May 18, 2012 05:22 AM
