Timing help
Old Sep 18, 2011 | 12:48 PM
hntnnut's Avatar
hntnnut
Timing help
I'm trying to check/set timing on my 96 F250 HD w/ 5.8w. I've found the spout, i've found and cleaned timing marks on the H. balancer. Now my problems are I cant remember what plug wire to conect the timing light clip to (I think #1), it been about 10-12 years since i've had to time a engine. My other problem is I can't figure out where the pointer is coming off the block. Oh and one last thing does anyone know which way the distributor rotates for advanceing/retarding the timing.
Richard
Old Sep 18, 2011 | 01:04 PM
f-trucker88's Avatar
f-trucker88
look down through the tensiouner and water pump pulley should see pointer number 1 wire yes i believe left rotation in the distributor move right for advance left for retard im not one hundred percent but i also believe 10 degrees is base time hope it helped. again may be a little off here myself
Old Sep 19, 2011 | 10:13 PM
skyfox10's Avatar
skyfox10
10° is base timing.
Right Advances timing
Timing marker is right up on top.
turnkyle
Aug 12, 2012 08:44 AM
wrreed
27
Sep 11, 2009 10:06 PM
Renzen
Jan 20, 2006 08:35 PM
VintageBlueOval
May 5, 2004 10:47 PM
ramato
Aug 30, 2000 11:29 AM
