Radiators!
Old Sep 18, 2011 | 08:51 AM
RA41126's Avatar
RA41126
Banned
Radiators!
What models years and types would fit as a replacement for an '83 with a 300? Going 'yarding and need one, but 83's are few and far, lots of later models there though.
Old Sep 18, 2011 | 09:37 AM
86fordtruck's Avatar
86fordtruck
I've got one I'm putting on Craigslist here in Memphis. Its from an 86, and will fit. Very good shape, but V8 engine swap dictates the change. E-mail me if interested.
Ron
ronbelldvm@gmail.com
Old Sep 18, 2011 | 03:13 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Radiators are from 80-84 and 85-96. Mounting is different.
Old Sep 18, 2011 | 04:42 PM
86fordtruck
My bad, Archion. You are correct. It wasn't apparent in the manual I was looking at, but when you said that, I checked my LMC catalog, and you are absolutely right. Of course, I can pull the lower mount brackets out of the scrap pile, too, along with the rubber mount insulators.
Ron
Old Sep 18, 2011 | 05:39 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The radiator supports are slightly different to account for the different mounting as well.
There are also a narrow and wide size radiators for the 300. Depending on your radiator support, you will either need the narrow or wide one.
300-6s have a "backwards" flow to all the other V8 radiators. It has to be from a 300 equipped truck.
Stick with 1980-1984 radiator for the 1983.
Old Sep 18, 2011 | 08:36 PM
RA41126's Avatar
RA41126
Banned
Thanx for the replies!
Waht do you mean a backwards flow?
Old Sep 18, 2011 | 08:50 PM
Franklin2's Avatar
Franklin2
I don't consider a radiator a junkyard item unless it looks brand new. The newer radiators are thin, some of them are plastic, and most were abused and are clogged with hard water deposits. I have used junkyard radiators for hard to find old vehicles, but these newer trucks are just too easy to find at the local store. I just looked up one for a 1980 with a 302 and they started at $166.00.
Old Sep 19, 2011 | 12:05 PM
81-F-150-Explorer
300-6 radiator...
Flows from top left to bottom right. Radiator cap on Right side. Tanks on sides.
V8 Radiators...
Flows from top right to bottom left. Radiator cap in middle or on left side.
grasfarmr73
Jan 18, 2013 09:37 AM
oklahoma rgs
Feb 2, 2011 05:40 PM
Steves55
May 3, 2010 02:19 PM
steve5140
13
Mar 31, 2009 05:37 PM
Uncle JT
Sep 12, 2002 08:30 PM
