what performance mods are worth it? [4.6L V8]
Old 04-26-2016, 08:16 AM
jbehuniak's Avatar
jbehuniak
jbehuniak is offline
4.6 will reallllly benefit from porting the heads/ aftermarket heads. By porting the intake runners, CC'ing the head a good polish and port matching to exhaust and have the surface machined flat you will pick up good power. Adding cams will make the best. This will require a tune but it will wake the truck up from 500RPM to redline. Its not as much work as you would think.
The ignition will help, but bigger injectors a higher pressure fuel regulator with a tune and ported heads will get you a large bang for the buck. (40-60hp)
Best thing about porting the heads is the engine looks stock so when you leave someone at the light you can- na man I just gots a cold air and headers.
So its like a package deal from the 70's just modernized
Remove the heads send them to the machine shop with the headers. The guy does what he needs to. Also give him the cams and he will install and set them up on the bench. get 40% or larger injectors and a high pressure fuel regulator. Contact a company that does tunes/chips, let them know how much the heads are ported, which cam's are in it what size injector and how much fuel pressure. They will write you a custom tune and you will be grinning every time the skinny pedal hits the floor.
The following users liked this post:
Old 08-04-2019, 03:13 PM
jamie dean's Avatar
jamie dean
jamie dean is offline
I have 09 f150 w/4.6 motor. Every time I look up anything from turbo kits to tuners my only options are for 5.4 motor. In comparison to 01-04 4.6 mustang motor what’s different as far as parts and internal or external performance parts? TIA!
Old 08-03-2023, 08:03 PM
steveyg123's Avatar
steveyg123
steveyg123 is offline
1st Gear
thanks for that bit of advise. i have a 97 f150 4.6 with a turbo kit from cxracing gathering dust in the garage. i'm going to pull the heads and do exactly what you suggested
waine5
04-07-2018 02:39 PM
R1dge_Runn3r
24
06-02-2017 07:30 PM
Mrhosedragger
1999 to 2016 Super Duty
17
04-28-2017 08:54 AM
Frank Murch
12-20-2016 01:39 PM
CharlyG
09-03-2016 10:26 PM
Quick Reply: what performance mods are worth it? [4.6L V8]
