Replacement header vs "performance" header
Old Sep 3, 2016 | 08:49 AM
CharlyG's Avatar
CharlyG
It looks like I found a weak spot in my "great deal". It looks like I have an issue with the first exh man bolt on the driver side. I see no bolt head, just a bunch of goop, that looks like liquid metal or something similar. It seems to be sealed so maybe I don't need to mess with it til it starts leaking? All the other bolts look fine.
I also have no real need for a performance header(I wouldn't get my money's worth for my needs) I just want one that works with all its bolts in place!
Old Sep 3, 2016 | 12:22 PM
Apocalypse's Avatar
Apocalypse
Well if you never want leaks and that's your main concern then pull the headers now and replace the bolts before the rest break. If you want to have a little update then yeah get the headers.
Old Sep 3, 2016 | 06:14 PM
WE3ZS's Avatar
WE3ZS
Yeah, eventually there will be more of the stock exhaust studs popping off, it's one of the few issues with these motors.
See my reply in this other thread that references this thread for more info and links to some other threads dealing with getting broken studs out.
https://www.ford-trucks.com/forums/1...old-studs.html
Old Sep 3, 2016 | 10:26 PM
z31freakify's Avatar
z31freakify
It's not only these motors it's mostly due to the aluminum heads having a different heat cycle than the cast Iron manifolds. The LS family from Chevy are far worst and more common than the Triton.
sprinter87
Modular V10 (6.8l)
Jun 3, 2008 08:47 AM
rsylvstr
Exhaust Systems
18
Aug 18, 2007 07:55 PM
Wakeboarder141
1978 - 1996 Big Bronco
Apr 19, 2004 10:43 PM
4spdboy
Mar 1, 2004 01:26 AM
DS02F250
Jan 22, 2004 01:25 PM
