HEEELLLLLPPPPPPP!
Old Sep 16, 2011 | 05:49 PM
ladyexpedition's Avatar
ladyexpedition
Angry HEEELLLLLPPPPPPP!
My heater in my 1997 expedition works in the back but not the front...Brrrrrrrrr !
Old Sep 17, 2011 | 06:29 AM
c_hohensee's Avatar
c_hohensee
Do you have the electronic controls or the dials? When you say it does not work is it not blowing air or just cold air?
Old Sep 17, 2011 | 08:26 AM
ladyexpedition
It blows its just blowin cold air........The back blows warm air though.
Old Sep 17, 2011 | 10:12 AM
EddieBauer02's Avatar
EddieBauer02
Ya..i have same prob. Only getting very little warm air out of the front..the rear is warm but cycles cold while at a stop light. Up front the door is moving..if press the button to go from 90 to 60 i can feel it make a diff so Im dnt think its the blend door...grr.
hope you get ur prob resolved too.
02 EB digital
Old Sep 17, 2011 | 10:46 AM
ladyexpedition
Mine might be the door...Im just wandering if its a do it yourself project?
Old Sep 17, 2011 | 11:44 AM
alloro's Avatar
alloro
It could be the infamous broken blend door issue, or it could just be the blend door motor. In either case, it is a DIY project only if you have the skills and tools necessary to do the job. That's something you would know better than any of us here.
Old Sep 17, 2011 | 12:01 PM
ladyexpedition
Alloro you have been a really big help.You helped me with the cop and it WORKED....It runs good.It has an exhaust leak but the muffler guy said it was a bolt broke on manifold not a cheap fix.Alloro do you have any info or illustrations on changing the motor or blend door...
Old Sep 17, 2011 | 01:25 PM
alloro's Avatar
alloro
Here's a thread that should give you some information: https://www.ford-trucks.com/forums/3...placement.html
Check post #6 for a link to some images of the dash removal and the repair.
Old Sep 17, 2011 | 02:43 PM
ladyexpedition
Thankyou for your help however i couldnt find the #6 post.
Old Sep 19, 2011 | 07:04 PM
mack6820's Avatar
mack6820
search it on Youtube. There are videos on how to do it on youtube.
Old Sep 19, 2011 | 07:25 PM
ladyexpedition
Ok ill try that thanks a bunch
Old Sep 19, 2011 | 08:59 PM
alwaysfords41's Avatar
alwaysfords41
A less technical and just as effective way is by using a through the glove box approach like Heater Treater does.
Old Sep 19, 2011 | 09:24 PM
alloro's Avatar
alloro
Thank you for your help however i couldn't find the #6 post.
Click this link: https://www.ford-trucks.com/forums/3...ml#post2437916
Old Sep 20, 2011 | 07:08 AM
Aero94EXP's Avatar
Aero94EXP
You may just need to flush your heater cores, that was the problem with my truck.
Old Sep 20, 2011 | 10:59 AM
EddieBauer02
Flushing my core's in hopes it helps..prob change out the thermostat too.. who knows how old it is.
Chris Ko
Jun 23, 2017 06:32 AM
doocrue
2009 - 2014 F150
Sep 23, 2012 07:23 PM
DWL
Jan 16, 2006 04:43 PM
scabbard
May 7, 2004 09:36 PM
