Rustproofing?
Old Sep 16, 2011 | 04:39 PM
maytag906's Avatar
maytag906
Rustproofing?
My 2011 F 150 Scab should be at the dealer in a few weeks. Do I get it rustproofed? Living in Northern Indiana, they use quite a bit o' salt on the roads.
My BIL has a 95 F 150 he bought new, and had Ziebart applied. It has a little bit of rust. But the 03 F250 Scab I'm trading in has as much, maybe a bit more, it wasn't rustproofed.
Just wondering what the masses think.
Old Sep 16, 2011 | 07:56 PM
SuperDutyScaler's Avatar
SuperDutyScaler
i live in NJ and the use normal salt, sand and that new liquid stuff ALL THE TIME! and my 2004 SD in my sig is holding up fairly well. I do wash it as much as possible in the winter though, i just bought Eastwood rust converter and did allthe body jointsunder my cab tonight actually. i was starting to get paint peeling and light surface rust. My bed supports are another story, ford must not prep the beds good on their trucks because my supports are getting that flaxy rust forming. If i bought anew truck i would do like i did before, wash it as much as possible in the winter, drence the undercarriage once spring hits and as soon as i see rust i would put Eastwood's rust converter on it asap!
Old Sep 20, 2011 | 04:36 AM
vans's Avatar
vans
If you plan to keep truck say 10 years, I would do it.
my 02 F250 is rusting, make me sick with the care I've given it.
I wouldn't be shopping for new truck if rust wasn't happening
SW Michigan Location
Old Sep 20, 2011 | 08:36 AM
MCDavis's Avatar
MCDavis
If you wanted to do it yourself, or apply your own coats after the dealer did theirs, then this stuff has been said to work quite well: Fluid Flim
Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
I lurk in the 2011+ SuperDuty forum from time to time and a large handful of those guys are using it often and in some nasty upper mid-west climates. Might be worth a shot too.
Old Sep 24, 2011 | 04:26 PM
murph1's Avatar
murph1
I have been spraying liquid wrench in all my vehicles for years..the door weep holes,the inside rocker panels,tailgates and such...worked very well for me...
I just started using Fluid film 2 yrs ago and I like the results that we have seen..it leaves a good film and doesn't collect sand...Ihave sprayed all the spots under the truck that seems to hold water and it looks very good so far..
After working at a rustproofing place when I was younger,I would never have that stuff put on mine..
I did restore a couple broncos a number of years back and had the Texaco Cosmoline sprayed in all the nooks and crannys...alot like fluid film..
in the summer the stuff will run a little so there is always protection on the metal..
thats my 2 cents..
Old Sep 25, 2011 | 03:04 PM
maytag906's Avatar
maytag906
My 03 F250 is getting bad, one of the reasons I have the new one on the way.
I may look into the Fluid Film. I also knew a guy years ago, who used ATF in the crevices, inside the doors, etc. Seems a bit messy to me.....
Old Sep 25, 2011 | 03:46 PM
jwill8957's Avatar
jwill8957
I just got my truck thursday night. They undercoated it for me and the next 5 years they will do it for free. Well see wat happens with it
Old Sep 25, 2011 | 07:14 PM
vans's Avatar
vans
I sold my F250 in about an 12 hour's after posting on craiglist, the guy called said he was serious and showed up with cash,
picking up my new truck Tuesday, it is getting the rustproofing done tomorow
Subzero68
Apr 3, 2017 08:07 PM
madscientist
Jul 29, 2015 01:25 AM
bamaf150
Jun 24, 2010 04:07 PM
3BadBirds
Oct 20, 2008 07:50 AM
jamesdraughn
Paint & Bodywork
Mar 16, 2004 05:39 PM
