Buy or fix
Old Sep 17, 2011 | 09:41 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Originally Posted by jplinville
Good point. Aroung here, what they call asphalt coating is actually a really thick, oil based product that is sprayed on with minimal dripping at first.
I'm assuming that he's talking about this...
I mean, if prepared correctly, I'm sure undercoating would be fine....And here's the only way i know to do it:
I was talking to a couple old gutter service guys one day, and they decribed a similar issue....They'd put the gutters up, 6 months later, they're dripping/leaking.....
One guy said he started using a small propane torch to quickly pass the flame over the metal, drying the surface THOROUGHLY, then he'd simply make his seal......
Makes sense if ya think about it, so that's the only way I know to do the undercoating.....Simply use a small torch and just pass the flame over the surface, drying it as much as possible, then following immediately with the undercoating.....(Which is actually a better idea than just lettin it dry, because the heat will help cure/harden the coating, etc......
Just food for thought...
Old Sep 17, 2011 | 03:36 PM
TopCoaters's Avatar
TopCoaters
Hey appreciate the advice guys. i have a good start on lets saying beautifying the frame, did all I can until I lift the bed to replace shackles and box mounts. Unfortunately I have caused myself a brake fluid leak and loss of brakes. I started a thread on it if anyone thinks they may be able to help. As for the solution to this thread I will continue to work on this truck and fix it up the best I can and if something comes up that I like better and that is in better condition then my current one I will jump on it and sell my current one.
Thanks for the responses guys. Heres to hoping I can fix my brakes tonight or tomorrow and prevent myself from using my Cadillac to lug lacquer around come monday morning.
Old Sep 17, 2011 | 03:40 PM
TopCoaters's Avatar
TopCoaters
changing front fenders
I did try searching this forum aswell as google and for some reason I can't find the information I need to what seems like it should be a simple task. I'm looking to replace both front fenders on my 93 f150.
Anyone willing to offer some help?
Thanks!
Last edited by TopCoaters; Sep 17, 2011 at 03:43 PM. Reason: Tried to delete as I meant to make this a new thread.
Old Sep 17, 2011 | 03:46 PM
SideWinder4.9l
Thanks!
About a 20-30 minute job....Each...
There's 2 bolts by the hood springs, 1 between the upper/lower hinges (PITA to get to), one under the fender on the outside (At the main bottom of the fender, behind the wheel).....2 that attach it to the radiator support...And 1 that connects the fendet to the lower stone guard (The metal piece that runs between the headlights, and under the grille.....and about 20 small screws....variously placed around the fender apron........
Keystone (Advance Auto) can get a new fender for ~$80....
Old Sep 17, 2011 | 03:52 PM
TopCoaters's Avatar
TopCoaters
I actually picked up both in mint condition off an old haul for 50. Have you heard of lmc trucks? If so what do you think of them. Sounds easy enough to change the fender. Maybe I'll do that tonight. Probably make dealin with my brake issue easier anyway.
Old Sep 17, 2011 | 04:00 PM
SideWinder4.9l
yeah, I've bought various doodads, etc from them...A set of wheels....Trim....
They have great shipping.....Reasonable, and prompt.....
I also like www.partsgeek.com for headlight bezels, etc....Headlights are like $38 SHIPPED......And they have always had my stuff shipped in 5 business days...ALWAYS...
srod333
Jul 10, 2019 11:02 AM
Kdr358
Aug 7, 2012 09:24 PM
grinnergetter
Jul 27, 2012 02:32 PM
sniper250
Aug 15, 2010 01:09 AM
Ken f2
May 8, 2010 10:35 PM
