Air filter set-up Okay??
Old 09-16-2011, 02:28 PM
01RangerDude's Avatar
01RangerDude
01RangerDude is offline
2001 Ranger 4.0 4x4
Ive ran it with 93 octane and put this filter on it & seen NO improvement whatsoever in mpg.
Someone told me that the filter might need to have some kind of a partition around it if Im going to use a cone style filter
I also have the metal tubing to go with it. I can put that on if that is the reason this high-flow air filter hasnt netted me any gains yet in mpg.
Anyone know if this set-up is okay?? Do I need a partition to block off the rest of the motor compartment that way it'll suck cooler air from underneath like it used to??
2 pics
Old 09-17-2011, 12:05 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Filter upgrades rarely result in MPG gains. If anything expect a little more power. The "partition" they are talking about is to isolate the filter from the hot air from the motor, so only cold air from the fender gets sucked in.
Old 09-17-2011, 06:58 PM
01RangerDude
1) I have seen many filters increase mpg. You have more power using same amount of fuel, therefore can go further. Mine is not for some reason.
2) I didnt ask what the significance of "partitions" are. I clearly stated WHAT they are used for and asked if my setup required one
Old 09-17-2011, 08:52 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
1) I could argue that day in and day out. So I wont.
2) I explained it. It keeps the hot air away from the filter so more cold air gets drawn in. Cold air is denser. Since the amount of fuel that can be burned is directly linked to the amount of air available, denser air equals more fuel that can be burned, creating more power.
uponyou21
Escape & Escape Hybrid
05-18-2009 10:45 AM
f15097
1997 - 2003 F150
06-25-2007 07:32 AM
ken1mod
Aerostar
13
11-24-2006 01:40 PM
ttam31
Alternative Fuels, Hybrids & Mileage
07-02-2005 07:50 PM
Musicman250
1999 to 2016 Super Duty
13
06-04-2004 12:02 AM
Quick Reply: Air filter set-up Okay??
