NEED HELP!!!!!!
Old Sep 16, 2011 | 11:44 AM
Stu13's Avatar
Stu13
Exclamation NEED HELP!!!!!!
I drive an 84 f250 351w. On my way to school this morning my truck would not accelerate properly. When I pressed the pedal it would accelerate for a little then die out. With my foot in it, it would only go about 15 mph. I had to pulse the pedal to get up to speed. When in neutral the engine will rev normally. This has happened 2 other times. Somebody cleaned the carb for me and said he cleaned the jets and sediment out of the bowl. The last time it happened, I used carb cleaner and put seafoam in the fuel tank and it worked fine. I'm at school and I dont want to go through this on the way home. Thanks for any help.
If it helps the carb is a holly 650 4 barrel.
Old Sep 16, 2011 | 12:12 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Sounds like your filter may be plugged, common on older trucks to have crap in the tank, especially if it sat for a while.
My1964ford
Jun 21, 2015 11:12 PM
Mando77ford
29
Oct 30, 2013 12:07 AM
Matty Fraser
May 26, 2012 09:58 AM
mrmechanic
Dec 7, 2009 04:43 PM
CJ360V8
May 15, 2002 10:16 AM
