Problem after cleaning turbo
Old Sep 16, 2011 | 01:47 AM
jlittle01's Avatar
jlittle01
So my mechanic said my turbo was sticking and I should either clean it or get a new one. So I cleaned it and now there is now power what so ever. I checked every thing and can find no visible problems. When I cleaned it i made sure the unison ring moved properly and that the actuator was in the same position as it was when I took it out. So any ideas what it could be.
Someone mentioned that 03's turbos have to relearn process when the the batteries are unhooked. Is this true?
Old Sep 16, 2011 | 02:05 AM
BigAlsPSD's Avatar
BigAlsPSD
I think you might have a little better luck posting this in the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Sep 16, 2011 | 03:26 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Sep 16, 2011 | 07:05 AM
npccpartsman's Avatar
npccpartsman
Unhooking the batteries forces the relearn anyway. Make sure that the VGT connector is installed properly and the wires arent pinched/broken. Double check for leaks in all the exhaust and intercooler plumbing.
Does the truck blow a lot of black smoke from a dead stop or does it have no power on "top end". Either of these could indicate non-operating vanes or VGT. Also, code scan the truck BEFORE you unhook the batteries again.
Old Sep 16, 2011 | 09:14 AM
Bkiggins's Avatar
Bkiggins
Double check the blue boots, Make sure they have not slipped off or they don't have pinholes. If you blow a boot you have no power at all and like npccpartsman said black smoke.
Old Sep 16, 2011 | 10:18 AM
High Binder's Avatar
High Binder
I had the same problem after cleaning my turbo but it turned out it was actually the MAP hose blowing out of the intake manifold. I put in a new fitting and hose and all is well.
Old Sep 18, 2011 | 02:29 PM
jlittle01's Avatar
jlittle01
Re: Problem after cleaning turbo
Thanks for all the help! I did a Turbo relearn and it works fine now. So now after a day and a half of no problems, there is a loud screach and I cant tell where its coming fun. I doesnt sound like its coming from the turbo but cant be sure. It happens totally random, high rpm, low rpm, high speed or low it doesnt matter. It happens for about 2-3 secs then goes away by its self. Any ideas?
Old Sep 18, 2011 | 02:41 PM
BLADE35's Avatar
BLADE35
have you ever changed the serpintine belt and belt tensiner
des it screech when turning A/C on/off
Old Sep 18, 2011 | 02:46 PM
BobbyB's Avatar
BobbyB
Could it be the exhaust pipes rubbing the fire wire?
ooopps.... firewall!
Old Sep 18, 2011 | 03:45 PM
High Binder
In case it is your turbo you might pull off the air cleaner assy and with your fingers feel for any axial play in the turbo. If you feel any play than it's out of spec. I believe Cheeze said the tol. was something like .007" but I could be wrong, either way it's so small of a tol. that any finger play is out of spec.
Just something worth checking.
oilfield
6.4L Power Stroke Diesel
Jul 12, 2016 07:23 PM
KDAVID1
Feb 12, 2016 08:43 PM
Bar B Q
Feb 22, 2015 06:34 PM
cajunsuperduty
Feb 20, 2012 09:50 AM
wuttrd
20
Sep 15, 2009 07:44 AM
