6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Strange turbo problems
Old Jul 12, 2016 | 07:23 PM
oilfield's Avatar
oilfield
I've had ford look into this but the dealership where i'm at is generally useless and because there wasn't a code they said there wasn't a problem. Truck is a 2010, straight stock.
What it started out as is whenever the truck would go into regen it couldn't hold lower amounts of turbo pressure at all. It would go up to 10-15psi then drop to 0. It would just oscillate like that until I put power into it and hard throttle I could get up to 20psi and it would hold there, and I could take it up to 25-26. Its been like that for probably a couple years now however I didn't drive it very much.
Now i'm working my truck a lot more daily, and this issue has progressed to now every day the truck does not run well. From a dead stop I have no power, I press into it and i'll slowly go off and then the big turbo comes in and get sucked back into the seat. Pretty much can't hold that lower amount of pressure all day and only got power if I step into it.
Sounds like small turbo is ****ed, however, no codes are being thrown.
I ran over a moose a few years ago, broke a sensor on top of the transmission (not sure which one), and I don't know if it could have wrecked another sensor along the way thats telling the turbo to do the wrong thing.
About once a month it would also blow a bit of blue smoke, burning oil somwhere. Probably the turbo I assume.
Any ideas would be greatly appreciated, thanks.
brendanlush
Mar 28, 2018 10:13 PM
firedaniel
Apr 4, 2015 10:02 PM
BobbyB
Sep 1, 2011 09:17 PM
guthrie&co
Oct 17, 2010 02:37 AM
billyboy
May 22, 2005 11:03 AM
