Removing steering column shroud
Old Sep 15, 2011 | 09:01 PM
thefordman1992's Avatar
thefordman1992
I have a 1985 f150 2wd auto with tilt wheel and i can not figure out how to remove the column shroud on the steering wheel. Can anyone help?
Old Sep 15, 2011 | 10:52 PM
rlester's Avatar
rlester
Just did it a week ago.,,
I had the instrument bezel off (the one with the two a/c vents) when I did mine.
There is a phillips screw on the bottom that comes out and then you have to spread it apart at the seam which runs all along the bottom. It helps to do this on a warm day, not when its cold. This way the plastic is pliable.
Hope this helps, I'm sure others will chime in with more details.
Old Sep 16, 2011 | 09:16 AM
4x484150's Avatar
4x484150
Yup, rlester's right. Did just what he said when I took the whole column out for new bearings.
Old Sep 16, 2011 | 10:37 AM
thefordman1992
Thank you all! Ill try my luck when i get off work
Old Sep 16, 2011 | 07:28 PM
thefordman1992
Ok got the shroud off and i replaced to ignition switch because i couldnt get the truck to start by turning the key. i had to get under the hood and jump the Solenoid to start it. After replacing the switch it still wont start. What now???
Old Sep 16, 2011 | 09:34 PM
Ken Blythen's Avatar
Ken Blythen
The solenoid itself could be faulty.
Old Sep 18, 2011 | 07:41 PM
thefordman1992
Already replaced it. Im thinking its wiring. Done checked the fuses
3TreeGuy
Jun 23, 2010 12:59 AM
big64
Jun 15, 2009 08:41 AM
blockheadbob
Jul 17, 2005 03:11 PM
robertmoore
Aug 22, 2003 07:37 PM
