Help - Does the timing on this 2000 5.4 look right?? I have pics.
Wanted to time the engine before I replaced the chains and tensioners. The crank shaft notch is at 6 o'clock the passenger side notch between the two gold links is at 11 o'clock, the driver side seems to be at 12:30....I did notice the lower side of the driver side chain is loose at this point and I have about 3mm of play in the links just in that section, hence a stretched chain.
Is this causing my mark to be more at 12:30 and when replacing the chain will it move to 1 o'clock?? Looks to be almost one tooth off - should I just move that cam over a tooth when I put the new chain on?? Am I on the right track? FYI - Number one piston is at TDC
Any insight would be helpful and much appreciated!!!... here's the pics...
Passenger Side
Driver Side
Driver Side
Passenger Side
Whole Engine Pic
Passenger Side
Driver Side
Driver Side
Passenger Side
Whole Engine Pic
Michael Sizemore
06-25-2003 01:43 PM
