Help - Does the timing on this 2000 5.4 look right?? I have pics.
Old 09-18-2011, 05:48 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Question Help - Does the timing on this 2000 5.4 look right?? I have pics.
Wanted to time the engine before I replaced the chains and tensioners. The crank shaft notch is at 6 o'clock the passenger side notch between the two gold links is at 11 o'clock, the driver side seems to be at 12:30....I did notice the lower side of the driver side chain is loose at this point and I have about 3mm of play in the links just in that section, hence a stretched chain.
Is this causing my mark to be more at 12:30 and when replacing the chain will it move to 1 o'clock?? Looks to be almost one tooth off - should I just move that cam over a tooth when I put the new chain on?? Am I on the right track? FYI - Number one piston is at TDC
Any insight would be helpful and much appreciated!!!... here's the pics...
Passenger Side
Driver Side
Driver Side
Passenger Side
Whole Engine Pic
snorindad
1997 - 2003 F150
05-16-2018 01:53 PM
HappySailor
Modular V8 (4.6L, 5.4L)
12-13-2014 03:35 PM
Chedz
08-26-2006 02:45 AM
Michael Sizemore
06-25-2003 01:43 PM
Quick Reply: Help - Does the timing on this 2000 5.4 look right?? I have pics.
