no start
Old Sep 15, 2011 | 10:38 AM
ff1210's Avatar
ff1210
no start
Ok guys my friends truck is not starting. The only way it will start and run is when he has it at WOT and it will only idle. It is a stock 95 with 240,000 auto. He has replaced the fuel pump,filter,and Cpm. When he replaced the pump he left a line loose and the pump is working cause it was leaking. NOTE all this stuff was replaced after it would not crank and it still want crank. any help would be great thanks......
Old Sep 15, 2011 | 10:52 AM
DIYMechanic's Avatar
DIYMechanic
I'm not sure I am following you. I thought you said it would run if he held the pedal to the floor. But you say it won't crank? We need a little clarification on what the truck is doing.
My first WAG is to check fuel pressure while cranking (should be around 20psi) or to unplug the ICP and try to start it that way.
When it runs does it sound like it hits on all 8 cylinders?
Edit: ICP, not CPS...too many letters floating around in my skull full of mush this morning...
Old Sep 15, 2011 | 11:09 AM
fordpride's Avatar
fordpride
Nate do you mean ICP not CPS ?
Old Sep 15, 2011 | 11:16 AM
ff1210's Avatar
ff1210
It will crank and run at it WOT but only idle. It was doing this before and after the changes. And it does sound to be hitting
on all 8. Neal and I were thinking it may be the TPS but was wanting some more ideas.
Old Sep 15, 2011 | 12:15 PM
DIYMechanic
Yup, you caught me! Truck won't run with the CPS unplugged! ICP on the driver side head.
Old Sep 15, 2011 | 12:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I also thought in the TPS, do you get CEL?. Ill check the IVS and TPS connectors (clean and lubricate for good contact).
Good luck.
Old Sep 15, 2011 | 02:04 PM
makomark's Avatar
makomark
Having spent too much time with the electronics connected to the pedal assembly, I'd doubt the APS (TPS). If the IVS shows idle, the PCM should set the pulse width to a minimal idle mode.
what, exactly, does "run at it WOT but only idle" mean? engine runs at 2000 rpm with accelerator pedal not being touched or something similar?
Last thought - remembering EOT sensor being "out of tolerance" can cause higher than normal rpms due to PCM 'thinking' engine is cold. Pretty sure you can unplug it (EOT) sensor, too, and PCM will assume a 'normal' default value.
Old Sep 15, 2011 | 02:27 PM
ff1210's Avatar
ff1210
Ok the truck will only idle and that's it nothing else. But it will only idle if you press the pedal all the way to the floor. When you let off the pedal it dies.
Old Sep 15, 2011 | 03:13 PM
DIYMechanic
How does it run when it is idling with the pedal to the floor?
Old Sep 15, 2011 | 03:42 PM
ff1210's Avatar
ff1210
It just idles n smoke.
Old Sep 15, 2011 | 04:42 PM
Hussler's Avatar
Hussler
I'm voting on the TPS from your description. Try unplugging the TPS, three wire cable and see if it will start and idle .. you should get a CEL also. If so then TPS must be shorting VREF (5 volts) that runs most sensors.
Another method if you have a volt meter is to connect the plus to the Gray/White wire and the minus to the Black/White wire on the TPS sensor cable. The voltage will be close to 0 Volts and when you push on the peddle it should slowly climb close to 5 volts. Do this with the key ON engine OFF.
Old Sep 15, 2011 | 05:12 PM
ff1210's Avatar
ff1210
No CEL have came on....
Stevejudy
Oct 24, 2018 10:50 PM
elite51203
Jan 25, 2016 08:23 PM
dogfennel
19
Apr 16, 2014 07:28 PM
medicbearusaf
Apr 8, 2007 08:03 AM
canadaler
Aerostar
22
Mar 28, 2005 06:05 PM
