Truck died like it ran out of gas, now crank no start.
So on my to way work today, the 2004 6.0 decides to die out like it ran out of gas. It will crank but wont start. If i crank it for a extended period, it will sound like its about to turn over and eventually slowly start. It will then idle and run, but when i push the acc pedal it dies out.
I got it towed back to the house. I have a AE and plan to hook it up tmrw.
What should I start looking for?
I unplugged the ICP and it still wont start.
I can hear the injectors clacking and i can also hear the fuel pump.
UPDATE-
I went out this morning and tried to crank the truck. It slowly started, (started easier than yesterday) after about 6 seconds of cranking. Yesterday when the engine was hot it barely started. It will run and idle fine, but when i push down on the acc, it will barely rev up to 1000 RPM's, no higher. When i put it in drive, it will die out.
Hooked up AE-
ICP while cranking-SLOWLY and barely gets to 500 then cranks. Will not stay running when put in DRive
FICM volts KOEO- 52V main power, 11.5 vehicle power
FICM sync- 1 YES
ICPR at 15% when KOEO, then while cranking goes to 85%
When engine did start, ICPR at 85% steady
Hooked up AE-
FICM sync- 1 YES
You are likely looking at doing an air test.
IIRC the 04 with ICP on valve cover might still have the old style HPOP, with new style wavy oil rails(?)..........someone correct me if I am wrong here but logic would tell me this if your ICP is on the valve cover pass side.
You should be able to tell if this is true just by looking at the HPOP cover. The newer style the HPOP actually sticks up through the cover.
So, normally my bet would be you are looking at an HPOP, but with the later style oil rails might also have stand pipes and dummy plugs that need attention.
Countless threads here and youtube about doing an air test.
Word to the wise........if it's the HPOP go with the better one and not the OEM.
http://www.thoroughbreddiesel.com/di...FQ6RaQodp7QGTg
You might try taking out the IPR first to check the screen, for debris and or damage.
Do you have any codes?
Not sure if AE can command the IPR valve closed, but you can get an air test tool for $90 that doesn't require jumping the IPR:
http://www.accuratediesel.com/shop/252.html
6.0L High Pressure Oil System IPR Air Test Tool
6.0L High Pressure Oil System IPR Air Test Fitting
Check IPR screen.
ICP barely at 500 and IPR at 85%... that's a fully open IPR supplying every drop of oil to build pressure and you can't make but 500psi...
It started easier in the cold morning because oil was thicker, after its warm, the leak flows oil better because of the thin oil.
YEP, you got a leak! Yep, you've got a late build.
If I can hear a leak, how hard is it to find? As far as determining if it's the HPOP.
Ive changed the oil cooler, done EGR delete, new turbo, so I'm not a stranger to this engine. I haven't been down under the valve covers however.
I'm at the point now where I dont know if it's better for me to fix it or just trade it in as it sits.
Ugggh frustrating.
Ugggh frustrating.
