Radiator Leak
Old Sep 14, 2011 | 07:38 PM
ruschejj's Avatar
ruschejj
Radiator Leak
My first radiator failure.
What the heck am I doing to these dang things. I traded my '08 with its fifth radiator installed and now my '11 has done the same thing.
Same exact issue, seepage at the bottom corner, driver side this time. Holds coolant all day when engine is running and hot. Overnight when it cools, things loosen up and coolant drips out. I had a wet spot in the parking lot about 6". Net enough to puddle, just wet pavement. I have been smelling coolant for a few weeks waiting to see what was going on.
I have 66,300 miles on the truck. As most of you know, I have a trailer in tow almost 85% of the time (actual stat backed by the nice info screen that stores trailer miles). I should crunch the numbers again, could be 90%.
Either way, this should not be happening with the way they have split the cooling system in an effort to keep things in check.
I hope all of you keep an eye on your rads. Might get lucky and just have a random issue here, but I don't think so. Very common problem since '08.
Old Sep 14, 2011 | 08:23 PM
Jessef250's Avatar
Jessef250
At the dealership in the last 6 months I've put 2 primary radiators in, and tomorrow will be putting a lower radiator hose due to leaking... Sorry bout your luck but this isn't a common thing
Old Sep 15, 2011 | 01:40 AM
ruschejj's Avatar
ruschejj
Good to hear. Thanks for the info.
Old Sep 15, 2011 | 06:53 AM
Marauder92V's Avatar
Marauder92V
Bummer! Hopefully it will be in and out quickly. Are you under an extended warranty?
Old Sep 15, 2011 | 07:46 AM
Jessef250's Avatar
Jessef250
The tech should have it done in little less than 4 hours, y'all are welcome!! It's what were here for
Old Sep 15, 2011 | 04:40 PM
ruschejj's Avatar
ruschejj
I do have an ESP but I will have to wait and see if it's covered.
Old Sep 15, 2011 | 04:59 PM
JReinert's Avatar
JReinert
I had the same thing at the exact same spot. Luckily I was still under warranty. I personally think these things should last longer than the truck, with proper maintenance.
Old Sep 15, 2011 | 10:45 PM
shadowSVT's Avatar
shadowSVT
don't see many 08-10's do you ???
pretty common deal on the 6.4's to puke the radiator, usually right after the 36K mile warentee expires.
I know some people who have gone through more radiators on 6.4's then turbos on the 6.0's.
Its pretty amazing that Ford can't step up and put a decent radiator in a $60K truck.
I WILL be watching mine like a hawk.
Old Sep 16, 2011 | 12:07 AM
Jessef250's Avatar
Jessef250
We see prolly 4-6 08-10's a month for radiators. And the 36k warranty doesn't apply anymore, as long as a hose is leaking then there is a tsb that covers the radiator until 100k.
Old Sep 16, 2011 | 06:36 AM
senix's Avatar
senix
Almost 56K on my 08 and i have the orginal radiator.
Looking briefly at the pic of the radiator above it looks to be of a similar design and materials.
Old Sep 17, 2011 | 12:48 AM
shadowSVT's Avatar
shadowSVT
local dealer told me the tsb will ONLY cover the radiator IF the thermostat inside the radiator is hyperextended and causes the failure, otherwise you pay for it. That may be BS, but thats what they said.
At any rate, how come there are radiators that are 20 years old with hundreds of thousands of miles on them and Ford can't seem to make one last 100,000 miles ???
Old Sep 22, 2011 | 12:12 AM
Jessef250's Avatar
Jessef250
The tsb with the hyperextended thermostats is history... The new tsb that I'm talking about (11-6-6) states if a hose is leaking along with radiator, replace radiator with either upper, lower or both hoses under warranty till 100k. Just beware if you have a 6.4, don't want anybody paying for this when ford will cover you!!
Old Sep 23, 2011 | 12:08 AM
shadowSVT's Avatar
shadowSVT
too late, I left my 6.4 in the rear view mirror, and I'm really glad I did.
I really liked my 6.4, but it never felt much stronger than my 6.0, and was much much worse on mileage.
Old Sep 23, 2011 | 07:36 AM
Jessef250's Avatar
Jessef250
And the 6.7 is a beast!!! Better mpgs, power everything! Glad you like it
Olds64
21
Jan 8, 2018 08:32 AM
lamb1133
Sep 24, 2017 12:49 AM
Cwmichael
6.4L Power Stroke Diesel
Oct 14, 2015 11:48 PM
bskier
Apr 18, 2014 06:55 AM
DmanNC
Dec 22, 2013 07:57 PM
