6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Heated Battery Blankets?
Old Sep 14, 2011 | 04:13 AM
Lonzom10's Avatar
Lonzom10
I've searched the site and the web in general for possible info on electric battery blankets but I have not been able to find much info, other than prices at local parts stores. I wanted to post and see if any of you in the colder climates used these? If so, which ones have you used and/or do you recommend? Probably a dumb question, but should I put these on both batteries?
I'm trying to get the truck ready for my first winter here in Soldotna, AK and would appreciate this and any other information you could offer on winterization. I've purchased the cord for the block heater and will attempt to install that myself in the next couple of days. I'll be changing the oil in the next month or so (Synthetic Rotella 5w-40) and I plan on purchasing a Winter Hood to cover the front grille. I also purchased an antifreeze tester and will check that out in the day or so as well. Outside of these things, any other suggestions for getting ready for winter?
Thanks!
Brian M.
Old Sep 14, 2011 | 07:33 AM
senix's Avatar
senix
I think the block heater is going to be the best thing to do. With the motor warmed up the batteries will have enough cold cranking amps to kick it over.
Test the anti-freeze is always a good idea.
Invest in a timer that you can set for 3 hours before departure.
Fordlu
Oct 6, 2016 05:11 PM
Benchwrench
Jan 31, 2011 07:10 PM
LilBlackCoupe
Dec 3, 2004 10:49 PM
GB
Feb 15, 2003 05:12 PM
MW95F250
Jan 27, 2003 09:22 PM
