Sponsored by: Real Truck
Warm and Fuzzy when Cold
Old Jan 30, 2011 | 09:07 PM
Benchwrench's Avatar
Benchwrench
So my truck won't catch cold this winter and future winters,
I am installing a couple 80 watt Battery wraps along with the coolant heater that comes on the truck.
Then there's a thermostat that will activate them at temps below 35 deg.
I have an idea that I wanted to get some feedback, I was thinking of installing a fender well battery tender rated at just over an amp. it's really for a boat or tractor used for storage but I thought since this device is so small, it might tickle the voltage while the wraps heat the battery casings.
Wadda ya think? good, bad, ugly? personally I don't think the trickle charger is going to do much of anything for 2 massive 1000 CCA batteries, but with freezing temps they really dip into their reserves to crank this tank over in the morning.
Old Jan 30, 2011 | 09:12 PM
wulfman's Avatar
wulfman
I think the batt wraps are a great idea and the charger can't hurt. Where did you get the wraps and how much do they cost.
Old Jan 30, 2011 | 10:21 PM
Benchwrench
the wraps are $20 from the local parts warehouse. They're called Kat's thermal wraps.
Old Jan 30, 2011 | 10:28 PM
sledheadm7's Avatar
sledheadm7
i also have 2 of the Battery wraps the block heater and a oil pan heater to keep my truck warm and they all plug in to a timmer that turns on before i go to work. also use 5-40 syn oil, and stanidine in the fuel. it may sound like i going a little over board but the weather system that is going through here right now its 25 below and wind chill of 45 below
Old Jan 30, 2011 | 11:23 PM
helomech's Avatar
helomech
Is this something you guys would suggest for a little less extreme weather on a V10? I live in SoCal, but at 6200 ft level. I've seen the winter get down to 17 degrees and 20-30's is pretty common, though, not for months at a time like other places. I was figuring on replacing the current battery with an Optima so I don't want to Kill that thing. $$
Old Jan 31, 2011 | 06:57 AM
wulfman's Avatar
wulfman
Benchwrench thanks for the info
Old Jan 31, 2011 | 07:49 AM
loganworks's Avatar
loganworks
Helomech if your truck wont start in those high temps LOL then you have a more serious problem. The only real reason to add a heater in your area would be to shorten the warm-up time.
Old Jan 31, 2011 | 07:58 AM
helomech's Avatar
helomech
LDub~ I haven't even been home to play with my truck yet. I'm still sitting over in Iraq. I'm just wondering what all I should buy online and have sitting at home waiting for me to play with. lol. Internet shopping... what a GLORRRRRRIOUS thing.
Old Jan 31, 2011 | 08:29 AM
KSCRUDE's Avatar
KSCRUDE
A .8 amp battery tender works great on a single battery sd. Tries it on a set of 4 batteries in semi truck and it never goes to full charge. So I get the 5 amp waterproof battery tender and it works great on 4 batteries at the same time. Get the 5amp and it will just play with your 2 baby 1000 cca pickup batteries. They will be on full charge and stay that way. 5 amp rocks on multiple batteries I guarrentie it.
Old Jan 31, 2011 | 06:12 PM
Benchwrench
The one I have is a 1.5A automatic float type. I have another one but it's not made to be mounted inboard, it's rated at 2A or 6A and not auto anything.
So if a 800mA would work on a single, then maybe a 1.5 would work for these two under the hood?
Old Jan 31, 2011 | 07:10 PM
KSCRUDE's Avatar
KSCRUDE
Yes I think a 1.5 would do the two battery setup. If my single battery is pretty low it takes my .8 amp 1 to 2 days to go to float mode. These little charger/maintainers are not fast but they work very well at maintaining your battery. I keep a .8 on my corvette 24/7 except if I unplug it to drive it. Never a problem. If a late model vette sets for a month or longer they say they usually won't start. I don't know as I never have let mine sit over about 2 weeks. They being the wizards on corvette forum.com.
Rusty Axlerod
Feb 28, 2023 11:19 AM
fordman75
Apr 16, 2013 11:37 AM
bigunit54
2004 - 2008 F150
18
Dec 6, 2011 11:10 PM
Geoff240ti
Feb 16, 2009 02:23 PM
