i need help please!!
Old 09-13-2011, 07:37 PM
bpayne88's Avatar
bpayne88
bpayne88 is offline
ok so like a morron i ran my truck out of fuel today..... on the way to the gas station. so i got two gallons in it and it cranked. it ran like crap of corse. i figured it would for a min. or so but i have driven it for about 5 miles now and it is still running bad. i put more fuel in it and when i cranked it at the station it ran fine until i pulled around the corner then bad again. i have done a buzz test and every thing sounds good. i did a contribution test and it put a code for 2,4,6,&8 cyl low contribution. i dont know where to look next. i am a mechanic by trade but i am NO diesel mechanic. please help.
Old 09-13-2011, 07:41 PM
bpayne88's Avatar
bpayne88
bpayne88 is offline
also forgot to add i have already tried the idm and checking the harnesess with no luck. but i can unplug the v/c harness on the bank 2 side and it does not change the way it runs.(shocker huh). but when i crank it for the first half of a second it revs fine then tries to die and runs like hammered $#!+.
Old 09-13-2011, 08:15 PM
fordpride's Avatar
fordpride
fordpride is offline
I would change the filter and clean the screen inside the fuel bowl its at 3 o'clock about a inch down you'll see a little hole use a Q-Tip with the cotton cut off. It could tak a
Little more driving to get any air out
Old 09-13-2011, 08:18 PM
Action4478's Avatar
Action4478
Action4478 is offline
Does it run the same on both tanks ?..
Old 09-13-2011, 08:44 PM
bpayne88's Avatar
bpayne88
bpayne88 is offline
the rear tank has had a problem for a while. i think that the pick up is clogged or something. and there is a differance in the way it runs even now between front and rear tank. i tried to clean the screen with no change either. im going to try and check the wires from the idm. i think it has to be a wire problem being since the whole 2nd bank is killed.
Old 09-13-2011, 09:28 PM
Ctkallday666's Avatar
Ctkallday666
Ctkallday666 is offline
yeah clean the screen on the fuel pressure regulator. have you checked the fuel pressure on the fpr? you can use a tire pressure gauge.
or could be a bad mechanical fuel pump.
Old 09-13-2011, 09:43 PM
bpayne88's Avatar
bpayne88
bpayne88 is offline
ok i figured out that it is deffinately isolated to the left bank. all the wires are good. does any one know what the voltage sould be at idle going to the injectors? also the #6 and 8 injectors ohmed around 6.5 on the outside uvch. so i think im going to start with the harnesses and a cps maybe. they are both origional to my knowledge, and im at 301,600 mi.
Old 09-21-2011, 07:27 AM
bpayne88's Avatar
bpayne88
bpayne88 is offline
ok so i fund that the uvch being old as father time himself does not does not make those things withstand the oil and high amperage of the glowplugs. so they shorted out and melted the connectors under the vc. when this happens the idm shuts down THE WHOLE BANK to save one injector since they all have a common supply wire. but $90 later and it runs good again.
SaintITC
05-05-2010 03:16 PM
BIG J82
04-20-2010 11:33 PM
seth1
03-24-2009 10:43 PM
Dstosh
17
01-31-2008 10:26 AM
fatswany
01-04-2005 07:48 PM
Quick Reply: i need help please!!
