Transfer case chirp...
Old Sep 13, 2011 | 05:46 AM
tloo13's Avatar
tloo13
Recently I replaced all 3 U-joints on my rear driveshaft and had it balanced. Now a few weeks after, I have a squeak or a chirp coming from the transfercase area and not sure what it is. It only happens first thing in the morning, or if the truck has been sittting for a few hrs, once it has been moving for a while it seems to go away.
Not sure what else to check and the noise is driving me nuts!!! I need help once again from all the experts on here.
Oh I also check all 4 calipers and none of them are dragging from what I can tell.
Thank you in advance
Tom
Old Sep 13, 2011 | 07:18 AM
riverrat41's Avatar
riverrat41
That is a tough one to find.Did you change the carrier bearring as well?Is the rubber about gone in it?I am sure you greased the slip joint while you had the drive shaft out?
Old Sep 13, 2011 | 07:26 AM
tloo13's Avatar
tloo13
The truck is a supercab, so there is no carrier bearing, and yes the slipyoke was greased real good. The spindle nut on the transfercase was a lil loose, so I tightened that also.
Old Sep 13, 2011 | 07:41 AM
riverrat41's Avatar
riverrat41
Gotcha...Those underneath noises are hard to find.I 270k on mine and has plenty of them from being in river bottoms and on the farm.Good luck.
Old Sep 13, 2011 | 08:36 AM
tloo13's Avatar
tloo13
Tell me about it, its so hard to pinpoint. Thanks alot ill post back if I ever figure this one out!!
Old Sep 13, 2011 | 09:09 AM
Fat Diesel's Avatar
Fat Diesel
Tighten the nut on the transfer case output yolk. Use a bunch of red loc-tite too!
Old Sep 13, 2011 | 09:40 AM
tloo13's Avatar
tloo13
I tightened it last nite actually, it was a little loos. Its got cranked down on pretty good, with a bunch of permanent loc-tite. it almlst sounds like it made it worse.
The worst part is that it goes away after about 10-15mknutes of driving. Could the bearing on the output shaft of the transfercase be on its way out? if so, How big of a job is it to change that out?
Big thanks again you guys for the help
Old Sep 13, 2011 | 10:21 AM
WA.Ranger's Avatar
WA.Ranger
Dan (KWIK) could tell you about breaking apart a T-case. Does the T-Case have plenty of fluid? I would change it out also if you haven't in the last year.
Old Sep 13, 2011 | 10:38 AM
tloo13's Avatar
tloo13
Yes sir, the fluid was changed as well, 2 qts of mobil 1.
Im at such a loss.
SDSC4X4
Feb 25, 2019 05:49 PM
dyhrdford
Feb 21, 2008 04:52 PM
bloomy63
Jul 26, 2006 09:09 AM
Cheggie
Apr 15, 2004 02:07 AM
TEEJAY
1997 - 2003 F150
Sep 9, 2003 08:38 PM
