2004 F150 Transmission problem
Old Sep 12, 2011 | 08:41 PM
lo-loc's Avatar
lo-loc
I've been searching the forums and haven't found anyone with the exact same problem. Truck is 04 supercrew with 5.4 and 140,000 miles. I have the typical shutter when cruising 55 - 60 and just ease on the throttle to pass someone. I chalked that up to the torque converter unlocking, if I punch it instead of easing into it, it will not shutter. As of yesterday, it acts like the converter is going to full lock up almost immediately. It will bang when it shifts and rpm's drop to lock up range. A few times it has killed the engine when I shift into D. No codes at all, I removed the programmer and installed the stock tune, no change, unhooked battery, no change, fluid is good, and twice after leaving stop signs it worked perfect until the next stop. I believe that it is an electrical control problem. Any ideas? Thanks
Old Sep 13, 2011 | 01:49 PM
COUNTRY0017's Avatar
COUNTRY0017
I have just started having this issue with my 07 once it gets to overdrive an I give it just a little gas I get a vibration an a noise that sounds like I hit some slow down strips in the road. But only in overdrive. With the overdrive off it doesn't make a sound. Had it at the dealership saturday an they did some kind of TSB flash I can't remember the number but it cost me 80 dollars even with powertrain warranty and it did nothing so it will be going back this week.
Old Sep 13, 2011 | 01:56 PM
COUNTRY0017
TSB 8-13-3
Old Sep 13, 2011 | 01:59 PM
COUNTRY0017
Sorry tsb 8-14-3
Old Sep 13, 2011 | 08:19 PM
lo-loc's Avatar
lo-loc
Went to the local tranny expert today. He said that it sounds like the TC lockup is not releasing. My code reader shows nothing. It goes in Monday morning, he is going to check operation and codes with his scanner, if it shows nothing he will dump the pan. He said that it sounds electrical, maybe a selonoid or the pcm, but if there is debris in the pan and filter, the torque converter is coming apart and will need full rebuild. What you describe is exactly how mine started, the first time it happened, I thought that I had hit rumble strips, that was about 10,000 miles ago. I am checking the harness and pins from the pcm to the trans tomorrow, if nothing, I will dump the pan and cut the filter apart myself. If I find debris , I will take it to the shop with me on Monday, if not I will probably order a Torque converter selonoid and try to repair it myself. Good luck, I'll post the findings as they come. Thanks
Old Sep 15, 2011 | 10:15 AM
COUNTRY0017
LO-LOC. Any up date on what u found I got mine back at the dealers right now for the 2nd time. Let me know what ya find an I will do the same thanks
Old Sep 15, 2011 | 01:23 PM
COUNTRY0017
My truck update is.......needs new torque converter. The parts will be coming from lakeland tomorrow. They was going to charge me for a new filter an I said is it gettin new fluid he said yes long story short no charge on the filter. I hope that fixes my issue I ll let u know.
Old Sep 16, 2011 | 05:19 PM
COUNTRY0017
Got the truck back today and they found a P1744 code so they changed the TCC solenoid an the torque converter. They said the resistance value out of range for TCC solenoid. So far it feels fine no shuddering. Does any one no what screen asy. is that the filter ???
Old Sep 17, 2011 | 08:10 AM
lo-loc's Avatar
lo-loc
Sounds great. I hope mine works out. It goes in Monday at 8. I'll post more when I find out. Thanks
Old Sep 21, 2011 | 05:20 PM
lo-loc's Avatar
lo-loc
Got my truck back from the tranny shop. Trans is junk, $2600.00 to remove, overhaul and put back in. 2 year 30,000 mile warranty. I'm still driving it for now shopping around. Glad your luck was better.
pearsonrb
2004 - 2008 F150
Sep 2, 2012 10:38 AM
ssjerrys
Oct 20, 2010 10:19 PM
ronxp2000
2004 - 2008 F150
Jul 1, 2009 10:14 PM
mwillis68
2004 - 2008 F150
Feb 23, 2008 08:44 PM
Randy8216
1997 - 2003 F150
Jan 29, 2007 05:08 PM
