Radio on by itself, now drain on battery?
The truck was parked under a metal roof garage and doesn't have a leak that I can find anywhere. It acts more like the key never gets turned completely off and not sure where the drain on battery comes from. I do have the aftermarket Turbo-save installed and not sure if that could have anything to do with it.
Was wondering if the lightning could have caused a computer issue with the main controls.
correct me if im wrong but this would be the part that needs replacing right?
Discount Car Parts Stuff - Car Accessories & Truck Accessories - Cheap Auto Parts - Car Cover - Floor Mats - Cargo Liner - ignition switch - 2003 Ford F-350 Super Duty Ignition Switch
sorry guys, so after a month of doing nothing lol, i checked everything with my auto teacher, and we found that everything one was fine, so we've narrowed it down to the relay behind the instrument cluster, also we found a wire from the breaker which the p/o had installed, to an unused fuse which was supplying constant power, when removed, radio/windows stopped working. will be taking that cluster off this weekend to see. i was wondering if anyone knew whether the fuse is replacable or does the intrument cluster has to be replaced. thank you
Subscribing. Mine is starting to do funny things like radio won't come on right away after starting the engine. Power windows don't work either until I hear a click behind the instrument cluster. There HAS to be a way to replace that relay instead of buying a whole new instrument cluster. I can't believe that's impossible.
