Oil pan replacement
Old Sep 11, 2011 | 05:31 PM
f350hoo's Avatar
f350hoo
Oil pan replacement
I'm going to replace the very rusty oil pan on my 2001 F350 4wd Diesel. The oil has started to seep thru at one place. I haven't decided if I'll raise the cab or take off the turbo in order to get the clearance I need. My questions for those who have done this are... about how far up will I need to raise the engine in order to swap the pans and is it best to jack the engine from below or lift it from above . Thanks for your help.
Old Sep 11, 2011 | 05:37 PM
ToMang07's Avatar
ToMang07
The entire engine needs to be removed and the engine turned upside-down to properly install/seal the oil pan.
https://www.ford-trucks.com/forums/1...-you-cant.html
7.3 Ford Rusted Oil Pan Repair Kit (1of 2) - YouTube
Old Sep 11, 2011 | 05:41 PM
f350hoo's Avatar
f350hoo
My pan is in really bad shape. I looked at this pan kit. I'm not going to go in that direction. Thanks anyway.
Old Sep 11, 2011 | 07:15 PM
F350-6's Avatar
F350-6
The engine has to come so far up that you might as well remove it. The oil pan gasket is just RTV (use the stuff from Ford / International since it's some really good stuff.) That means you'd have to jack it up far enough to remove it and let it sit for a few days for the oil to stop dripping. Then clean, apply RTV and pan and let it set up.
It would be quicker to just pull the motor and flip it over so you have no drips to deal with.
Old Sep 11, 2011 | 07:29 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Drill out the rivets and remove the crossmember. Just replace with grade 8 bolts. If my oil pan ever gets too rusty thats what ill be doing.
Old Sep 11, 2011 | 07:50 PM
mjtpolice76's Avatar
mjtpolice76
Is there a writeup on the best way to remove the engine
Old Sep 11, 2011 | 09:08 PM
f350hoo's Avatar
f350hoo
I am really interested in doing the rivet removal. I have a concern about being under the truck when the last rivet is removed. I'll have to look at it in the morning. Thanks to all.
Old Sep 16, 2011 | 03:09 PM
VQ2Fast4U's Avatar
VQ2Fast4U
As long as the truck is on level ground i cant see the crossmember being any trouble. As for that video of the fiberglass oil pan coozy hahaha.
Old Sep 16, 2011 | 04:23 PM
puller45's Avatar
puller45
Has anyone actually tried doing this?
Old Sep 16, 2011 | 04:27 PM
snakedoc's Avatar
snakedoc
i have seen where guy cut it and the welded it back. to me the rivets would be a better idea.
Old Sep 16, 2011 | 07:44 PM
Larry_the_handyman's Avatar
Larry_the_handyman
As long as your front bumper and lower cross member are on I can't imagine it would go anywhere. Those with 2wd would have to remove the traction beams which seems equally difficult.
Tugly
Aug 15, 2016 11:09 AM
79sparky
Nov 12, 2013 10:03 PM
szotty
18
Oct 23, 2010 11:23 AM
johnsteffy
23
Sep 22, 2010 07:23 PM
NY Signman
15
Nov 9, 2004 05:54 PM
