oil pressure problem
Old Sep 11, 2011 | 01:14 PM
proia's Avatar
proia
Post oil pressure problem
i have a 95 4.9l when cold oil pressure is 45psi when hot pressure is between 20-30 psi driving and at idle 12-15psi i change oil alot 20-50 sae truck has 255,000 mi.
Old Sep 11, 2011 | 08:21 PM
F-250 restorer's Avatar
F-250 restorer
Are you making us wait in suspense before you actually ask a question?
Old Sep 11, 2011 | 10:23 PM
piglett's Avatar
piglett
sounds like the old engine mite be well worn. what brand of oil have you been using & how long have you had the truck? also how many miles have you put on it in the time you have owned it
piglett
Old Sep 11, 2011 | 11:35 PM
52 F-1's Avatar
52 F-1
That sounds normal to me, actually really good considering the mileage though i might expect higher with that thick oil if it had less miles.
The oil pressure is usually higher at start up then drops when the engine heats up and the oil pump doesn't spin as fast at idle but the passages are still the same size so its obviously going to drop a lot there, though at idle it doesn't need as much pressure either.
Old Sep 12, 2011 | 09:27 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Rule of thumb to remember. As long as you have 10psi per 1K rpm's, you are fine. Maybe not the greatest, but adequate.
mike L
16
May 18, 2020 10:39 AM
proia
Sep 12, 2011 03:33 PM
Wicked Endings
Feb 20, 2011 11:02 AM
Ranger GT2
Apr 3, 2007 02:57 PM
Matty
Feb 12, 2002 11:19 AM
